Please help
driver1
PostPosted: Mon Dec 25, 2006 4:50 am    Post subject: Please help Reply with quote
My '78 924 is sparying too much fuel, with all the injectors pulled to look, as soon as I hit the start/crank all of them spay a stedy fuel flow and I don't think it's supposed to do that, wich of course it floods it out .
My thought is it's in the fuel dist. , I just relaced it with another "rebuilt" I was told and noticed also fuel is leaking from there also, not at the air box but at the seam where it seperates.
Any thoughts?
Lizard
PostPosted: Mon Dec 25, 2006 6:54 am    Post subject: Reply with quote
you would need to adjust the air fuel mixture screw,
but if fuel is leaking from the fuel dizzy housing then it isnt sealed, you may be able to take it apart and reseal it, but I wouldnt hold your breath.
3 928s,
driver1
PostPosted: Tue Dec 26, 2006 5:28 am    Post subject: Reply with quote
I adjusted it all the way to the lean side and it still flows out as soon as the pump is on
