agghh!! my expansion tank cap just disintegrated!
Tiny
PostPosted: Fri Nov 24, 2006 2:10 am    Post subject: agghh!! my expansion tank cap just disintegrated! Reply with quote
GSF car parts don't have one in stock anywhere in the country!!
Does anyone in the UK have a source or even a spare i could buy?
pretty please!!
Tiny
*****1981 - 924 - Auto - London, UK******
Lizard
PostPosted: Fri Nov 24, 2006 6:20 am    Post subject: Reply with quote
it should just be a standard 13PSI rad cap, same as most fords/chevies, as well as some VWs
3 928s,
Tiny
PostPosted: Sat Nov 25, 2006 6:36 am    Post subject: Reply with quote
ok cool...got one and fitted
i thought it was the reason she overheated.... pegging the red yesterday....but today after running her up to temp...the cooling fan didn't kick in....so it looks i am chasing a gremlin tomorrow
grrr
thanks buddy
tiny
Ozzie
PostPosted: Sat Nov 25, 2006 12:29 pm    Post subject: Reply with quote
Join the two wires on your radiator fan switch.
If the fan runs then you have found the problem.
Its AUTO and its BLACK
Montego Black on black/red
spiraloutse4n
PostPosted: Tue Nov 28, 2006 5:40 am    Post subject: Reply with quote
What does this mean? with my 924 i had the same problem with the fan not turning on at temperature, we got a brand new fan switch and it still didnt engage the fan, so we solved the issue by wiring the fan to always be on - but is there a better way?
Ozzie
PostPosted: Tue Nov 28, 2006 8:09 am    Post subject: Reply with quote
The rad fan is controlled by a temp switch, a resistor and relay.
A fault in either one will cause failure of the fan to operate correctly.
If the switch closes but the fan doesnt come on then the resistor or relay is at fault.
Of course I'm assuming the wiring and fuses are ok.
The resistor and relay are in parallel circuits.
The relay bypasses the resistor when the ign is on and the fan runs at full speed when the switch is closed.
If the ign is off the fan runs at slower speed until the rad cools.
For twin fan systems it gets more complicated.
Tiny
PostPosted: Wed Nov 29, 2006 8:28 pm    Post subject: Reply with quote
thanks guys - great advice
luckily for me it was the fuse
tiny
