AppleBit
Posted: Thu Nov 09, 2006 1:56 pm Post subject: Good News - HOLY CRAP! |
\\\ Continued from 'Bad News'... ///
What is the firing order of the Porsche 924?
1, 3, 4, 2 right?
Well, looked at the cam tonight on both the 924 and the 931.
When the engine is on TDC:
#1 / Fire #3 / Compression #4 / Intake #2 / Exhaust
You need to wire up the spark & injectors for each coil as such:
Coil #1: 1 & 2
Coil #2: 3 & 4
So the same goes for the fuel injectors.
This might be it folks. Something that so many people have overlooked.
I wired it for the spark properly now, but the injectors won't be done until Sunday. I'll take the car to the dyno's again and see what happens.
BTW: The cam timing was also off by 1 tooth. Thanks guys for telling me to check it again... I would have, and did... but I have had professionals do this for me multiple times. I have a pissed off, yet happy feeling going on right now. _________________ Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine |
Min
Posted: Thu Nov 09, 2006 1:59 pm Post subject: |
so, does it run any better?
AppleBit
AppleBit
Posted: Thu Nov 09, 2006 2:03 pm Post subject: |
| Min wrote: | so, does it run any better?
Min |
No, runs worse.
Think about this: The car was tuned and was starving for fuel (because before the spark was firing on the fire stroke and the intake stroke- shortening the amount of fuel it burnt)
Now that the spark is not consuming the fuel on the intake stroke, there is an overwhelming amount of fuel on cold start. I suppose I could try to let it run, but its also difficult since the fuel injectors are squirting and puddling up most of the fuel.
It needs the fuel injectors wired up properly and a full new tune. _________________ Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Min
Posted: Thu Nov 09, 2006 2:08 pm Post subject: |
Tuning is the best part. Good luck to you.
endwrench
Posted: Thu Nov 09, 2006 2:37 pm Post subject: |
Hope this works out for you but I have to add, I have my injectors wired into a single wire wich fires all the injectors just once per 2 revolutions and it idles like a dream and runs like a banshee.
Also, the Tec-3 Honda data is correct about how the coils should be routed.
AppleBit
Posted: Thu Nov 09, 2006 4:16 pm Post subject: |
| endwrench wrote: | Hope this works out for you but I have to add, I have my injectors wired into a single wire wich fires all the injectors just once per 2 revolutions and it idles like a dream and runs like a banshee.
Todd |
Unfortunatly I took the supposed Electromotive specialists word for it when they said exactly what to do. GGGGGRRRRR
And I found my notes on what he said - cauz I wrote it down word for word and remember verifying the stuff later by calling him up only to bold it even more... GGGGGRRRRR
OHh well, I am sure this is it!
w00t!!!!! _________________ Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Posted: Thu Nov 09, 2006 5:18 pm Post subject: |
Not sure I understand you jon...
your system is setup in waste spark right?? so opposing cylinders are firing at the same time...
If you fire on the intake stroke you'll blow the intake boot right off... but that would be assuming your injectors are batch firing like endwrench is talking about... I thought you would be running sequential....
I would seriously be verifying the TDC marks on your cam and crank, hope these aren't set for a missing tooth. If it is then your advance tables will all be out by the same amount. 32 teeth = 11.25 degrees right??
AppleBit
Posted: Fri Nov 10, 2006 12:03 am Post subject: |
| leadfoot wrote: | Not sure I understand you jon...
Leadfoot |
Waste spark = yes
TDC marks = true
crank and cam were verified not by marks until the cam and crank were verified by physically where they are located = Verfied correct
Go back a few and look at when cyl 1 is on fire, where cyl 4 is (exhaust) _________________ Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Racing
Posted: Sat Nov 18, 2006 9:02 am Post subject: |
Apple.
Iīm with raceboy here.
Having read the entire thread,my first thought was timing or lack of ign energy.
So..
Verify like raceboy wrote.All stand alones work the same,and there isnīt an engine in existance thatīll deliver without timing in the right spot.
I donīt care how much fancy parts you throw at it.
Again.
The basics,and frankly speaking...read up.
Reasons are plentifold.
Cause..what labours WILL break down..and in such a scenario i for one at least think that YOU should be the one capable of repairing it.
The different trigger setups around ainīt all that hard when you just accept that the manual is like a class back in school revisited.
Just do it bro...and be done with it.
For the record.Nope.If engine sounds as it should(mechanically) iīd say that itīs probably JUST the timing that needs to be adjusted.
As far as ignition energy.
If you run the coil that electromotive recomends..my bet is that thereīs a table that says "coil charge time" as well.(probably under ign outputs or similar)
Just look the table up to make sure that the charge time is somewhere between 2 and 3 milliseconds. |
AppleBit
Posted: Tue Nov 28, 2006 10:14 am Post subject: |
maby you should host one of those partys where lost of members come and in the end of the day after 1 Kg of meat and 10 beers per person the engine problem is solved. maby some dude will come up with some ideeas and you can benefit from your work. _________________ Supercharger and EFI kits
https://www.the924.com |
AppleBit
simsport
Posted: Tue Nov 28, 2006 11:57 am Post subject: Jumping in |
Hi here
Can I ask. Is the megasquit sequential or block fire?
If sequential then you would wire the injectors up differently to block.
Sorry if this was already dealt with in the thread!
Also what type of throttle pot is used?
I made a lot less power until I realised the pot I was using was not linear . As soon as I went to a linear pot up came the power.
Seems a shame to drop this work after all the cash you have spent.
First principles always seem to help me ie
Mechanicals ok, compression etc, fuel pump, coil/coil pack ok then....
Good fuel and signal....right time.
Good spark and trigger..right time.
Valves open/shut good seal, right time.
Some things give themselves away, such as power dropping away gradualy as revs increase...almost always fuel shortage, check pump , check injectors/map.
Sudden power drop...almost always ignition..... but can be det in a boosted engine.
Sorry again if all this has been dealt with, hate to see a good man defeated!
Cheers
Simon _________________ Blown is always best! |
endwrench
Posted: Tue Nov 28, 2006 2:36 pm Post subject: |
Simon,
He is running an Electromotive Tec 3 setup and I believe he is running sequential.
Applebit,
I'm with Simon in that I hate to see you give up on this thing but it is your money (and sanity ) so best of Luck on the V8 project! Hope your not opening another can of worms.
I really wish I lived closer to you so I could help you sort this out. I have no doubt it can be done and I love a challenge like this. Makes me want to buy your motor just to do it.
