Joes924 Guest
Posted: Sat Feb 23, 2002 5:08 pm Post subject: |
Quicke what size are they ?I know but im hoping someone will tell me ..
Posted: Sat Feb 23, 2002 5:38 pm Post subject: |
| 10mm |
Joes924 Guest
Posted: Sat Feb 23, 2002 5:55 pm Post subject: |
Thanks I mean to take the head off the block there bigger than 10mm ?
Benski Guest
Posted: Sat Feb 23, 2002 11:36 pm Post subject: |
I seem to remember that the bolts on my '80 head were triple-square (12 point allen). It took a 12mm triple-square to get them off.
Is that what you were asking or did you want to know the diameter of the sheath of the bolt? |
Posted: Sun Feb 24, 2002 12:02 am Post subject: |
if we're about the 10 "in-hex" allen bolts that hold the head down, the last lot I took off came out with a 10mm allen socket.
The outer diameter of the bolt head is probably about 13mm but the key that goes in has a 10 stamped on it. |
Joes924 Guest
Posted: Sun Feb 24, 2002 4:23 am Post subject: |
bought a big set of allen wrenches only to find that the bolt pattern was of the star type ..
[ This Message was edited by: Joes924 on 2002-02-25 14:10 ] |
