mdaniel83 Guest
Posted: Tue Feb 19, 2002 8:49 am Post subject: |
hey all, ok i have brought up this question before but no one attempted to answer it, anyways here it goes
when i shift to a neutral and pull it side to side, it makes a clinking noise what could it be? |
JvGinPDX Guest
Posted: Tue Feb 19, 2002 8:58 am Post subject: |
| If you hear it while it is in neutral and your foot is not on the clutch it would be your gears grinding against each other. Do not do that. It is nothing to worry about. |
Alex Roy Guest
Posted: Tue Feb 19, 2002 9:35 am Post subject: |
If it is just a clinking noise and not a grinding noise, I would say it is your bushings in your linkage.
Joes924 Guest
Posted: Tue Feb 19, 2002 10:45 am Post subject: |
Alex a project in progress .. I like the job you did on the inside..
