crank sensor clearance
PostPosted: Wed Sep 20, 2006 4:54 am    Post subject: crank sensor clearance Reply with quote
what is the clearance between the engine position sensor tips and the flywheel? Thanks
Ozzie
PostPosted: Wed Sep 20, 2006 7:16 am    Post subject: Reply with quote
on a 2.5 lt motor you mean?
Its AUTO and its BLACK
Montego Black on black/red
PostPosted: Wed Sep 20, 2006 8:03 am    Post subject: Reply with quote
yes, I am sorry, I did not specify. Replaced engine position sensor mount. It is slightly adjustable for height. Would like some idea of where to set it before i put the clutch housing back on.( 87 924S)
PostPosted: Wed Sep 20, 2006 8:44 am    Post subject: Reply with quote
0.8 mm
Email me and I will email a copy of the procedure.
PostPosted: Fri Sep 22, 2006 8:37 am    Post subject: Reply with quote
is that .8mm for both sensors or just the one over the pressure plate teeth?
PostPosted: Fri Sep 22, 2006 9:43 am    Post subject: Reply with quote
Did you get the procedure I emailed you?
PostPosted: Sun Sep 24, 2006 4:41 am    Post subject: Reply with quote
yes, and it seems to say they both are the same clearance.
PostPosted: Sun Sep 24, 2006 4:53 am    Post subject: Reply with quote
Nope, you adjust the brackett that holds them both so that the one that senses the flywheel teeth has .8 mm clearance.
PostPosted: Thu Sep 28, 2006 4:37 am    Post subject: Reply with quote
the engine runs so it must be ok. thanks
