mdaniel83 Guest
Posted: Thu Feb 14, 2002 1:59 pm Post subject: |
hey guys, i just put a new timing belt in 22 miles ago and it has snapped tonigh.
i am going to go to the dillership tomorrow. and i'll be bitching big time about the defect timing belt.
any ideas why would it snap? it ran perfectly for the first 15 miles then i guess it skipped a tooth and then it snapped
[ This Message was edited by: mdaniel83 on 2002-02-14 15:09 ]
[ This Message was edited by: mdaniel83 on 2002-02-14 15:09 ] |
Joes924 Guest
Posted: Thu Feb 14, 2002 2:29 pm Post subject: |
I posted long ago about the time I put one on and the teeth started comen off oh every few spots around the belt and it finally stopped turnen on the bottem of the crank
there were no teeth to move everything ..
anyway it was a new belt to ..
mdaniel83 Guest
Posted: Thu Feb 14, 2002 2:38 pm Post subject: |
| do u think it's just a bad belt? |
Joined: 29 Jul 2001 Posts: 9066 Location: Royal Oak, MI, USA
Posted: Fri Feb 15, 2002 12:44 am Post subject: |
Sounds like you didn't have it tensioned properly, if it skipped a tooth.
How did you set the tension?
mdaniel83 Guest
Posted: Fri Feb 15, 2002 2:25 pm Post subject: |
aight, it was tensioned properly but i think i have figured out the problem, one of the bolts on the bottom got unscrewed and was touching the belt, i guess it started stretching cuz of that and finally broke, dillership replaced the belt and i will be puting it in tomorrow
thanx god it's a 924 not 924s or 944 the valves are fine |
