mdaniel83 Guest
Posted: Thu Feb 07, 2002 2:44 pm Post subject: |
ok here's something i want to know. today i started a car and after a few mins of running i tried to rev it up i press the gas to the bottom and it would rev up to 3000 rpm's and drop down to about 1500 - 2000 rpm's, after it warmed up it would rev up to 4000 and drop after that...is it my compression? and what exactly would cause that.???
btw i can hear some knocking somewhere in the engine. would that compression cause that if it is a compression
please HELP
[ This Message was edited by: mdaniel83 on 2002-02-07 16:25 ] |
Rick MacLaren Guest
Posted: Thu Feb 07, 2002 11:50 pm Post subject: |
Dunno about the knocking...could be unrelated.
Check CO2 sensor attached to cat. |
Pat Guest
Posted: Fri Feb 08, 2002 3:14 am Post subject: |
| I agree it could be the oxygen sensor, but check the timing also. |
mdaniel83 Guest
Posted: Fri Feb 08, 2002 3:31 am Post subject: |
| ok screw the knocking...tell me about the rpm's why do the drop after i floor the gas |
Posted: Fri Feb 08, 2002 4:02 am Post subject: |
Your engine tuning's off and you have a blown headgasket.
dpw928 Guest
Posted: Sun Feb 10, 2002 4:27 am Post subject: |
Concerning the knocking, try running your valves again. Concerning the shutting off, it sounds like your ignition timing is too advanced. Check you timing and vacuum advance and retard lines to the distributor. Is it missing at low rpm's? If not it is doubtful you have a blown head gasket.
Dennis |
