firemn131
Joined: 16 Jul 2008 Posts: 57 Location: Lusby, maryland
Posted: Sun Oct 19, 2008 2:01 pm Post subject: No turn signals |
the dash undicator lights but does not blink. No indicator lights on the outside.
All works ok as far as the emergency flashers.
I changed the relay....no joy.
Any help appreciated
John _________________ 1987 924S Daily driver 64 miles each way to work.
2001 F-150 my back up
1970 Mercury Cougar XR7 The Muscle. |
Vince Ponz
Posted: Sun Oct 19, 2008 10:39 pm Post subject: |
Try replacing the bulbs. Sometime previous owners put in the wrong bulbs. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Ozzie
Posted: Wed Oct 22, 2008 7:54 pm Post subject: |
I had exactly the same problem. Emergency flashers work fine but no indicators.
Never found the cause and had to wire a second relay into the system.
I can put a modded wiring diagram on here if you are interested _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
firemn131
Posted: Thu Oct 23, 2008 11:45 am Post subject: Got Lights back |
Thanx guys. All lights work now.
I haven't had an issue with the power loss in about 3 days. That was 400 miles ago.
I am sure that there is another chapter to the saga about to unfold.
talk later.
Mike924
Posted: Sun Oct 26, 2008 9:03 pm Post subject: |
So what was the problem? ...and the fix? _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
firemn131
Posted: Mon Oct 27, 2008 1:51 am Post subject: PROBLEM AND FIX |
I don't know!
I drove it all week. no problems about 600 miles.
then today leaving church i started it and I heard it surging. I mean the idle rpm was fluctuating from 700 to 1200 then it shut off. I went in the church for5 a couple minutes it then started fine and ran good.
I have notice that for a while now I don't hear any escaping back pressure from the gas cap when I refuel. I think there is supposed to be consistent back pressure in the system.
I also smell,,,,enriched exhaust or something like incomplete/unburnt carbon before it leaves the exhaust. hard to describe, maybe like pre-ignition or kinda like a dieseling effect. I dont know how to describe.
Any thoughts?
Mike924
Posted: Mon Oct 27, 2008 5:58 pm Post subject: Re: PROBLEM AND FIX |
| firemn131 wrote: | | I went in the church for a couple minutes it then started fine and ran good. |
That's the power of prayer!
First step is to thoroughly check all vacuum lines, etc for leaks... _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
