justinw77
Joined: 25 Jul 2006 Posts: 20 Location: Highlands North Carolina, USA
Posted: Tue Jul 25, 2006 9:29 am Post subject: How do I get a 1982 924 running? |
I just purchased a 1982, 924. I was told the car never stopped running, but wasnt used. I have never worked with Porsche before, so I would appreciate information on this. I just need to know what basics should be covered, such as fuel filter, plugs, wires, or fuel just to get the car running. I also need to know if there is anything particular to working with a porsche.
Thanks for your help. |
StienbargerR
Posted: Tue Jul 25, 2006 10:26 am Post subject: |
What seems to be wrong with it? Does the engine crank or turn over at all? I think we need the specifics of what the car sounds like, and what it is doing. Im confused...does it run right now, or not?
But some good things to replace are-
Spark plugs
Distributor cap and rotor
Fuel filter
Air Filter
New oil and oil filter
New gas is always good.
How long did it sit? Did the owner tell you whats wrong with it? _________________ 1978 924 NA
mhart
Joined: 24 Feb 2006 Posts: 170 Location: New York, NY
Posted: Tue Jul 25, 2006 11:45 am Post subject: |
my best advice - pray
other than that, things to check include all the filters, tune up parts (plugs, wires, distrib), all the front of engine belts, rollers and seals, and the engine mounts.
Beyond that, you'll have to just fix the problems as they pop up (as problems tend to do on 20+ year old cars) _________________ '87 924 S - No sunroof and a few modifications |
justinw77
Posted: Tue Jul 25, 2006 11:46 am Post subject: Thanks |
| Thanks, that helps. I havent had a chance to turn it over yet, and as far as I know there arent any mechanical problems, just needs to be cleaned up and tuned up. Ill let you know when I get it running. Thanks again. |
Chrenan
Posted: Tue Jul 25, 2006 1:03 pm Post subject: |
How long since it was run? Is the fuel bad? Varnished? Jelly? Rings rusted to cylinder walls? Those are some of the worst case scenarios.
A Porsche engine is like any other, needs air, fuel and spark. If any one of the ingredients is out of whack, it won't run. _________________ 1987 951 - M193 Version for Japan |
Joined: 29 Jul 2001 Posts: 9061 Location: Royal Oak, MI, USA
Posted: Tue Jul 25, 2006 10:08 pm Post subject: |
RTFAQ - it's all in there. _________________ Vaughan Scott
