wdb Guest
Posted: Tue Feb 12, 2002 1:03 am Post subject: |
| I saw on ship shape yesterday,the host upgraded the boats electrical system from fuses to a circuit breaker panel,would it be possible to do that to a car and what would be the benefit other that not having to buy fuses |
Posted: Tue Feb 12, 2002 2:22 am Post subject: |
Very common on racecars.
numbers Guest
Posted: Tue Feb 12, 2002 6:56 am Post subject: |
| Actually, you can buy circuit breakers that fit the original sockets on you fuse panel at any good autoparts store. They are not very expensive, and work quite well. Advantage is that if a fuse blows, you must replace it. The circuit breaker will just reset. Disadvantage is, you probably will not fix the underlying problem that is causing the breaker to pop since it resets itself. That can lead to more serious problems. |
