d12-Matt Guest
Posted: Fri Feb 01, 2002 5:33 pm Post subject: |
| What type of fuel do you guys use in your 924's? I heard that too low of octane can cause detonation in high compression engines. Last time I did a compression test all the cylinders showed around 140-150 PSI. Does that mean I need to use 91 octane fuel? Also, how would I be able to tell if detonation was occuring? |
Posted: Sat Feb 02, 2002 3:54 am Post subject: |
Regular 87 octane should be fine, unless you've tweaked the engine at all... I run 89 octane in the racecar, with more advanced ignition timing.
Roger Hall Guest
Posted: Sat Feb 02, 2002 10:21 am Post subject: |
| maybe i like wasting money but the sticker says 91 octane so i use the 93 octane. |
Posted: Sat Feb 02, 2002 10:49 pm Post subject: |
Yeah, seems like you do - those ratings are to old standards, RON rating as I recall... labels at the pump are an average of RON and MON (R+M/2), and therefore lower for a given blend.
Save your money.
Roger Hall Guest
Posted: Tue Feb 05, 2002 2:19 pm Post subject: |
| thanks i will |
numbers Guest
Posted: Wed Feb 06, 2002 7:51 am Post subject: |
| 85 octane is probably adequate for an NA, but for you Turbo owners, be sure you use the highest octane rated fuel available in you area. |
