seanski44
Joined: 13 Mar 2006 Posts: 532 Location: Nottingham UK
Posted: Sat Apr 08, 2006 3:16 am Post subject: 924 turbo exhaust manifold bolt |
Hi all,
Finally got the exhaust off the 931, got the Jpipe out of the way and am really struggling to remove the third hex bolt from the exhaust manifold. you know the one, its the one above the oil filter etc...
Any suggestions? (I've already broken a UJ trying) its had many doses of WD40.... _________________ 1998 BMW Z3 2.8 arctic silver & red
1981 168HP 931 S2 blue/tan leather - SOLD
1985 121HP 924 2.0l na modded - SOLD!
1992 968 lux SOLD
1989 944 2.7 lux SOLD |
bass gt
Joined: 02 Dec 2004 Posts: 971 Location: Johannesburg for now!!
Posted: Sat Apr 08, 2006 3:39 am Post subject: |
Sean,
Just keep going at it!! I broke 2 UJ's trying to get the 3rd bolt out of my spare engine It just takes time, brute force, ignorance and a gallon of WD40. One little tip i found. When the two faces start to seperate, squirt WD in there. It seemed to help, although mine came off in tiny increments.
Good Luck,
Steve |
John Brown
Posted: Sat Apr 08, 2006 4:07 am Post subject: |
If (and it's a big if) I'm understanding the particular hard to reach bolt (of the many); consider removing the oil filter, adapter and all the oil lines in the way. At which point you can go straight up the side of the block with a long extension.
All that stuff could probably use new O-rings and crush seals anyway. I know mine did. _________________ John
80 931 - #931 44Cup
99 Escalade - tows track cars
seanski44
Posted: Sat Apr 08, 2006 4:10 am Post subject: |
cheers guys, I'll be back under there tomorrow! - might be a good idea to remove all the oil gubbins anyway (yes you've got the right bolt!)
Pray for the good weather to remain! _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
seanski44
Posted: Sat Apr 08, 2006 4:13 am Post subject: |
Actually, while I'm at it, the goal is to remove the head, as the car was bought as a cambelt failed non-runner. I am doing the righ thing in removing the head with the ex mani attached (in the same way as I did with the n/a) ?
btw, what's the worst case scenario for snapped cambelt? - (I have a spare 931 head but it may not be in as good condition as the one that's in place) _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
-nick
Posted: Sat Apr 08, 2006 5:15 am Post subject: |
Removing the head with the exhaust manifold attached is definitely the best way. You'll have a tough time with some of those manifold-to-head nuts even with it out of the car.
Absolute worst case scenario with a snapped timing belt = cracked head, scored cylinder walls, broken piston(s). Your valves are very likely bent. If the head of one snapped off then it could have scarred the cylinder walls badly and could even crack a piston. Most likely, you just have bent valves...
ps- PB Blaster works much better than wd40!
nick |
seanski44
Posted: Sat Apr 08, 2006 9:35 am Post subject: |
| -nick wrote: | Removing the head with the exhaust manifold attached is definitely the best way. You'll have a tough time with some of those manifold-to-head nuts even with it out of the car.
nick |
Cheers, haven't heard of blaster, will check at the FLAPS for it! - mabe not avail in the UK...
Am hoping its just bent valves, that way I can combine the two heads I have to make one good one. The spare has a threaded injector but all being well, the two will make one good one! - and yes, hoping for no scarring in the bores.
On inspection, I can see daylight between the cam lobe and number1 inlet tappet, so I'd imagine that's a bent valve for starters, if the head of it had snapped off I'd guess not to be seeing daylight... so, 1 down, 7 to go! _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
seanski44
Posted: Sun Apr 09, 2006 4:27 am Post subject: |
Update,
well, my brother came round to help and while he held the torch, squirted the WD40 and held a spanner up there to keep the UJ as straight as poss, I attacked (gently) with my 18" torque wrench...
Looked into removing all the oil pipes etc, but having removed the filter, we realised that on the RHD the steering knuckle is in the way of getting the pipes off...
anyhow, with a lot of grunting we noticed that I was actually pulling the head of the bolt to one side rather than turning it. The up side of this was that we were able to get some WD40 in under it in one of these moments, and we slowly managed to make it turn about one revolution before April showers set in and stopped the show... well, a bit of rain would have been fine and wouldn't have stopped us, but it began hailing! - anyway, it cleared up once my brother had gone back to his family of course! - back at it again tomorrow... _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
seanski44
Posted: Mon Apr 17, 2006 11:33 pm Post subject: |
bolt off, now made a start on the head bolts, one of which is rounded
will post in the 931 tech sec but any advice is welcome. Looks like someone reused the original bolts at some point, or else attempted to remove them and failed miserably... _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
Khal
Posted: Tue Apr 18, 2006 9:58 am Post subject: |
Sorry, missed this thread.
We recently had exactly the same problem with my car. Removed the oil cooler, etc... (as John Brown suggested) to get a clear run at the bolt. Sprayed it liberally with penetrating oil. Much elbow grease finally saw it come loose, no damage.
I think the trick is to leave the other two bolts in and attack the third bolt first... _________________ '80 924 Turbo |
seanski44
Posted: Wed Apr 19, 2006 1:47 am Post subject: |
| Khal wrote: | Sorry, missed this thread.
I think the trick is to leave the other two bolts in and attack the third bolt first... |
Cheers Khal, got it sorted without removing oil cooler, its now off.
Problem now is the rounded head bolt. _________________ 1998 BMW Z3 2.8 arctic silver & red
1992 968 lux SOLD
