gasoline direction injection
Keaton
PostPosted: Fri Apr 21, 2006 5:13 pm    Post subject: gasoline direction injection Reply with quote
gasoline direct(oops) injection what do you guys know. i've googled it and fount some information it. what do you guys know?
oops thats what i ment
Khal
PostPosted: Fri Apr 21, 2006 5:15 pm    Post subject: Re: gasoline direction injection Reply with quote
I know mine doesn't have it.
'80 924 Turbo
Mike924
PostPosted: Fri Apr 21, 2006 5:20 pm    Post subject: Reply with quote
Do you mean direct injection?
Direct injection squirts the fuel directly (hence the name) into the cylinder (i.e. after the inlet valve) as opposed to into the inlet manifold like normal (i.e. before the inlet valve).
The biggest difference is that direct injection needs to overcome the compression of the cylinder as opposed to the vacuum of the inlet manifold.
Most (all?) diesels are direct injection, very few petrol (gas) engines are (I can only think of one, the Mitsubishi GDi).
What's on your mind, Keaton?
Keaton
PostPosted: Fri Apr 21, 2006 5:26 pm    Post subject: Reply with quote
yeah i know that all diesels have it. i know that they are starting to put it in Gasoline cars. pros? cons?
moone924
PostPosted: Fri Apr 21, 2006 5:42 pm    Post subject: Reply with quote
That new 2.0 turbo audi engine is direct injection.
Ryan Moone
Always shopping for a nice s2 931 to baby.
New philosophy : one car project at a time.
Khal
PostPosted: Fri Apr 21, 2006 6:26 pm    Post subject: Reply with quote
Keaton wrote:
pros?
Better than any other method.
Keaton wrote:
cons?
924 doesn't have it.
'80 924 Turbo
Mike924
PostPosted: Fri Apr 21, 2006 6:29 pm    Post subject: Reply with quote
Khal wrote:
Keaton wrote:
pros?
Really?
Seems to me that it's a complicated method of replacing something that works fine already.
Khal
PostPosted: Fri Apr 21, 2006 6:30 pm    Post subject: Reply with quote
Mike924 wrote:
Seems to me that its a complicated method of replacing something that works fine already.
What isn't? Still goes better.
'80 924 Turbo
PostPosted: Fri Apr 21, 2006 11:12 pm    Post subject: Reply with quote
Mike924 wrote:
Khal wrote:
Keaton wrote:
pros?
Really?
Kinda like marriage, eh?
Khal
PostPosted: Sat Apr 22, 2006 4:36 am    Post subject: Reply with quote
Wouldn't know... hope to find out...
'80 924 Turbo
PostPosted: Sat Apr 22, 2006 11:07 pm    Post subject: Reply with quote
It's much more efficient - step up in power and economy. Same complaints could be said of going from carbs to fuel injection.
Mike924
PostPosted: Mon Apr 24, 2006 5:29 pm    Post subject: Reply with quote
True. When BMW brought out the 2002 Tii, with its Kugelfischer mechanical injection (similar to the Bosch CIS), pundits thought they were mad for not sticking to tried-and-tested Weber DCOEs.
