daniel
Joined: 18 Jun 2009 Posts: 686 Location: Sydney, Australia
Posted: Sat Mar 20, 2010 4:00 pm Post subject: Adjusting CIS Mixtures |
Hi All
If I add or remove washers under the system pressure regulator will this adjust the overall mixture or should I look for another method?
Cheers
Daniel _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
Posted: Tue Mar 23, 2010 4:53 am Post subject: |
No, that'll only increase/decrease system pressure. A:F adjustment is shown near the lower-left here -
 _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Wed Mar 31, 2010 4:44 pm Post subject: |
You can raise pressure by changing the shim that goes along with
the spring, kind da fuzzy there but thats it.
You adjust the afr by turning the adjuster located on the top of the aluminum cover that the fuel dizzy is mounted on.
Theres a rubber plug in therepull it and use a long torx bit
still fuzzy here though I think counter clock-wise will richen and clock-wise will lean it out. Make adjustments with the car running, turn the
adjster in in small increments then waite to see the effects.
Some say to turn it one way till the motor falls off idle then the other way till the motor falls off idle again then go to the middle and richen it up a little from there. The best way is to go find someplace with a afr tester.
Again more fuzz though I believe the over all mix is set 14.3.
The afr tester is a taill pipe tester that reads the mix. If you do it on your own, running lean will destroy the motor,
richen it up from the middle a bit & if you get black sooty stuff coming out the exhaust lean it out a bit. Again the best bet is a afr tester.
You could be all the wiser and get a afr guage and install it in the exhaust.
afr= air fuel ratio.
Did I do good Smoothie.  _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Arvidw
Joined: 20 Sep 2009 Posts: 227 Location: The Nederlands (Europe)
Posted: Wed Mar 31, 2010 6:17 pm Post subject: |
| Joes924Racer wrote: | | use a long torx bit |
Make it a 3mm allen wrench  _________________ Porsche 924 2.0 Kompressor 136.1wHp @ 5650rpm / 201.9wNm @ 3900rpm (dyno @ dp-engineering.nl) |
Joined: 28 Feb 2008 Posts: 1423 Location: Washington DC area
Posted: Wed Mar 31, 2010 11:54 pm Post subject: |
My Benz has K-Jet and we adjust for 12.8 reading with a wideband sensor for max power at wide open throttle under load.
Chuck _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
