Radiator Fan
mdaniel83
PostPosted: Thu Jan 03, 2002 3:09 am    Post subject: Reply with quote
Hey guys, how's it going...
other then turn sigs and horn, i got another problem, my rad fan doesn't work when the car overheating...I have checked the fan and it's working, I have changed the Temp switch, but still the fan doesn't work when the car overheats, any suggestions?
Diesel
PostPosted: Thu Jan 03, 2002 6:08 am    Post subject: Reply with quote
How do you know it's overheating? If it's 'boiling over' you could have a head gasket that's letting compressions into the cooling system, fooling you. You might have a plugged radiator. You might also just need a good burping. I would use a non-contact thermometer to actually see what the temp of the water neck is when you are heating up.
marky522
PostPosted: Thu Jan 03, 2002 2:06 pm    Post subject: Reply with quote
IF you need a fan stup i have one kicking around.
Let me know,
Mark
mdaniel83
PostPosted: Thu Jan 03, 2002 3:37 pm    Post subject: Reply with quote
no diesel I know when it's boiling and when fan doesn't kick on....
i changed the thermostat too, but it still doesn't work...i think its a wiring problem..
some guy who sold me this car had fun with bypassing everything in the car so now nothing works
d12-Matt
PostPosted: Thu Jan 03, 2002 4:50 pm    Post subject: Reply with quote
Mine does the same thing. The thermostatic fan switch worked last time I took it out and tested it, but I'm getting a new one anyway. It should fix it, because it doesn't overheat at all if I bypass that switch. Could it be that an air bubble or something in the radiator would prevent it from working properly?
Roger Hall
PostPosted: Sat Jan 05, 2002 2:48 pm    Post subject: Reply with quote
Turn signals, fan and horn all have relays on the block above your fuse panel. I would bet thats your problem. Check the ground first then the block. Then the relays themselves the haynes manual gives the procedures.
Body Shop Rob
PostPosted: Sat Jan 05, 2002 3:29 pm    Post subject: Reply with quote
Maybe the engine needs a coolant flush. Air in the coolant system can cause problems, but if your fan is working maybe the coolant is too old. Remember to ad half coolant and half water to maximize its properties.
dpw928
PostPosted: Sun Jan 06, 2002 9:27 am    Post subject: Reply with quote
The fan should have a constant 12 volts to it and the switch completes the ground. You should be able to bypass the switch by connecting the two switch wires and your fan will turn on. If not you are not getting 12 volts to the fan (check your relay and fuse) or you have a bad ground coming off the switch. BTW is you new switch 75C or 83C?
Dennis
d12-Matt
PostPosted: Mon Jan 07, 2002 6:41 pm    Post subject: Reply with quote
I thought the switches only come in 82C or the standard 92C. I'm getting an 82 degrees one because it's kinda warm here in California.
mdaniel83
PostPosted: Fri Jan 18, 2002 6:52 am    Post subject: Reply with quote
hey Dudes..what's going on?
well can anyone tell me is there a relay or a fuse (or both) for the radiator fan?
d12-Matt
PostPosted: Fri Jan 18, 2002 4:08 pm    Post subject: Reply with quote
I think there is a relay for the radiator fan. It is located on the top left corner of the relay panel when viewed from the front. It's right next to the fuel pump relay, which has an extra thing sticking out on it.
Another thing you should check is the connector that plugs into the radiator fan motor. If it's like mine, it's really close to the alternator pulley, and if the engine shakes enough it can hit it and knock it loose or cut through one of the wires inside.
[ This Message was edited by: d12-Matt on 2002-01-18 17:10 ]
Roger Hall
PostPosted: Mon Jan 21, 2002 12:35 am    Post subject: Reply with quote
there is also a resistor you should check also on pre 78 its mounted by the temp switch. 79 and on its mounted under the dash drivers side. If you go to the tech section theres a great section on fans.
