FASTdan
Posted: Fri Mar 03, 2006 1:33 am Post subject: audi TT/VW turbo engine in 924? |
this may be completely out of the question (or maybe its been done to death, i dunno! lol) but has anyone considered transplanting the 1.8T audi TT/golf GTI engine in to a 924? 225bhp out of the box and all the modern tricks and reliability?! And an easy 300bhp with a few mods!
Again, I may be talking fantasy but it is a popular conversion over here in the uk for mk1/2 golfs (VW rabbits to you guys maybe?) and seems to be a pretty universal engine - bearing in mind the 924's audi/VW engineering.
Any thoughts? _________________ 1980 924LUX |
Posted: Fri Mar 03, 2006 1:38 am Post subject: |
isnt the golf5 a transversal mounted engine ?....dunno...it would fit...but with mods to mounting...electrics and drive line.
a gti engine or a TT engine would cost as much as a 951 engine....i dont see why swap to VW or Audi when there are Porsche options. _________________ Supercharger and EFI kits
https://www.the924.com |
FASTdan
Posted: Fri Mar 03, 2006 2:15 am Post subject: |
225bhp out of the box (on baby boost) and about 20 years newer in design - but perhaps like you say the problems would outweigh the benefits? transverse mounting shouldnt matter i wouldn't think? main problem would be mating to the bell housing i suspect - as I have just realised the 924 engine is mounted at that wacky angle, something you couldnt do to the 1.8T engine unless you had special sump modifications etc.
Im not particularly clued up on the 931 engine - as to what power can be had for what cost. What boost do they run as standard? as 177bhp from a 2.0 turbo isnt mind blowing, bearing in mind a ford escort RS turbo runs 135bhp on the same bosch k-jet and 7psi boost on a wee 1600 lump (and was designed around the same time in history). _________________ 1980 924LUX |
Posted: Fri Mar 03, 2006 2:52 am Post subject: |
as far as i know its 0.6 bar for the 931...and the 2.0L Turbo GT-S makes @250 HP..now whats something...even today. _________________ Supercharger and EFI kits
moone924
Joined: 05 Feb 2003 Posts: 868 Location: Douglas Wyoming
Posted: Fri Mar 03, 2006 12:11 pm Post subject: |
There's a engine swap forum at the bottom of the forum list....
I'm pretty sure this has been discussed before...... _________________ Ryan Moone
Always shopping for a nice s2 931 to baby.
New philosophy : one car project at a time. |
CBass
Posted: Fri Mar 03, 2006 3:15 pm Post subject: |
Mounts are all wrong. You have to cut the whole mounting assembly out of the VW donor car, and weld in brackets to support the mounts.
The bellhousing pattern is different. You can modify the 924 bellhousing and clutch, which is probably the easiest way of doing it, or you can chop up a VW tranny to do it... Good luck with the latter. Modifying the 924 bellhousing involves extensive fabrication, machining and welding.
Wiring is completely different. CIS vs Motronic IIRC. It's all there though, nothing too complicated just tedious.
Other than that, simple and easy as swaps get  _________________ '81 931 in various states of assembly |
Mike924
Posted: Fri Mar 03, 2006 6:20 pm Post subject: |
Dan, forget your hot-hatch past - yuo've got a grown-up's car now!  _________________ 1985 Porsche 924 'Lux', Kalahari Beige (my ex)
FASTdan
Posted: Fri Mar 03, 2006 11:04 pm Post subject: |
| Mike924 wrote: | Dan, forget your hot-hatch past - yuo've got a grown-up's car now!  |
LOL unfortunately my hot-hatch would show my grown-up car the way home every day of the week
but i cant help but think the 924 might be a pretty good base for a project, hence the questions and that 1.8T engine seems to be proving itself in all sorts of vehicles. _________________ 1980 924LUX |
Posted: Sat Mar 04, 2006 1:50 am Post subject: |
just put a tutbo on the old 2 liter...it will make 180 hp...as the 1.8 T does. _________________ Supercharger and EFI kits
Posted: Sat Mar 04, 2006 12:24 pm Post subject: |
My wife's TT 1.8T makes 225 hp stock and can make almost 300 with a different chip and 93 octane (US Pumps). _________________ White 87 924S "Ghost"
