Ants Guest
Posted: Tue Jan 15, 2002 9:41 pm Post subject: |
Hey guys
I've been reading previous post about starting probs. but to no avail with my prob.
My 1980 931 seems to flood everytime i try and start it, it will turn over and over and not catch, when i remove the relay for the fuel pump it will start and run until it uses up the fuel in the line, then when i replace the relay it will start OK.
Can anyone tell me why it won't start initially, is there too much fuel getting to it.
cheers
Ants
badenkb Guest
Posted: Wed Jan 16, 2002 1:10 am Post subject: |
HI
Based on my own problems...check the position of the air sensor, maybe its too high allowing too much fuel into the engine .
Ian |
AznDrgn Guest
Posted: Wed Jan 16, 2002 1:53 am Post subject: |
| Check your cold start valve also. If it continuously runs or runs while the engine isn't cranking it might flood the engine. |
numbers Guest
Posted: Wed Jan 16, 2002 9:22 am Post subject: |
| For all of the years that I suffered with the hot start problem with my 931, I thought that it was flooding. However, it turned out to be that I actually was not getting enough fuel. |
Ants Guest
Posted: Wed Jan 16, 2002 8:11 pm Post subject: |
Cheers Guys
I'll have a look at the weekend
Ants |
