CC Rider Guest
Posted: Tue Jan 15, 2002 4:54 am Post subject: |
| I'm looking to redo the cooling system on my '85 924 and am looking for a radiator. I've just started, but all the radiators I have found are listed as '88 and newer. Is this the same? |
numbers Guest
Posted: Tue Jan 15, 2002 8:16 am Post subject: |
| I believe that the 924S uses the same radiator as the 944. It is different than the original 924 radiator. All of the original 924's use the same radiator, including the Turbo. If you are looking to purchase a new radiator, I suggest the heavy duty radiator sold by Performance Products. If you are looking for a used radiator, I have one that you can have cheap. |
wdb Guest
Posted: Tue Jan 15, 2002 5:53 pm Post subject: |
| call your local radiator shops and ask if they can install a larger core for your radiator, its the best way to go and will be cheaper.they take the end tanks off and replace with a thicker core. |
kevrl Guest
Posted: Tue Jan 15, 2002 7:19 pm Post subject: |
But will the 944 Radiator fit in to the 924 ? from what I can see in pictures it looks like it should fit, except for the mounting system. But I can't quite make this out. Is the 944 radiator thicker ?
I am interested because new 944 rad's are available quite cheap over here in the UK |
