headlights
jamez
PostPosted: Tue Jan 08, 2002 6:51 am    Post subject: Reply with quote
hey guys. my headlights are screwed up.. they go up fine and the lights turn on, but they wont go back down, the headlights and side markers turn off, but the tail and interior lights stay on... anyone know what the problem could be??
JvGinPDX
PostPosted: Wed Jan 09, 2002 11:40 am    Post subject: Reply with quote
Mine did that too. As a test, remove the rubber boot from the motor while the headlights are up and the headlight switch is off. Turn the black knob. If your lights go back down, your headligh motor is probably ok. Your relay would be suspect. You could either replace it, or open it up to sand some crud from the contacts. I did the latter, and it solved my problem.
jamez
PostPosted: Wed Jan 09, 2002 2:39 pm    Post subject: Reply with quote
nope my relay and motor are fine, the lights go up just not down.. I can push the relay contact with my finger and they go down, I think it must be my headlight switch.. is there another relay for the headlights besides the one on the motor?
PostPosted: Wed Jan 09, 2002 11:03 pm    Post subject: Reply with quote
No, that's the only one. Look at a loose contact at the connector for the motor - do things happen if you wiggle it? It's very common, as noted in the FAQ.
jamez
PostPosted: Thu Jan 10, 2002 9:02 am    Post subject: Reply with quote
I found the problem, one of the diodes on the motor was fried, I put a new one in and it works great...
wdb
PostPosted: Thu Jan 10, 2002 1:25 pm    Post subject: Reply with quote
how did you know to check that a diode was bad,or did check every thing till you found the problem.
jamez
PostPosted: Fri Jan 11, 2002 12:53 am    Post subject: Reply with quote
well there are 2 diodes, I think one for up and one for down. so if your motor only goes one way, like mine did, its probably a diode. plus I tested the relay and switch..
SpiNko
PostPosted: Fri Jan 11, 2002 4:44 am    Post subject: Reply with quote
I had the same trouble, they came up, but not down. I think I tryed everything, even the relay. I desided to crack open the motor and have a look. one of the 2 diodes was fried. I determined this by the plastic around the diode was semi burnt, like it had heated up before it died. I replaced it with the same diode from a dead motor off my parts car, and bada bing, bada boom, the motor worked great.
