gautney
Joined: 11 Oct 2005 Posts: 19 Location: Salt Lake City, Utah
Posted: Sat Oct 29, 2005 1:43 am Post subject: Clutch Cable |
Does anyone know where to get a good cluch cable from? Any tips on installation? Any advice would be helpful.
Thanks! _________________ 1998 Boxster
1979 924
1962 356b |
Chrenan
Posted: Sat Oct 29, 2005 1:46 am Post subject: |
I would get it at the dealer, it is not going to be an expensive item. _________________ 1987 951 - M193 Version for Japan |
timstar92404
Joined: 22 Sep 2004 Posts: 2075 Location: richmond BC
Posted: Sat Oct 29, 2005 6:14 pm Post subject: |
go to lordco or nappa they had it here. like 25 bucks.
its easy to replace you just reach at the back of the pedal and unhook and unscrew it from the plastic hook pieces then pull it out from the firewall then just disconnect it from the holder.
you have to set the correct distance/ freeplay on the new one.
my distance does not match with haynes either haynes has a mistake or there is something wrong with my clutch. _________________ 78 924 sold.
85.5 944 |
Trogdor
Posted: Sun Oct 30, 2005 4:46 pm Post subject: |
| It's super easy, if you can, buy the sweet bronze fittings w/cotter pins for the ends to replace those terrible plastic end fittings. The only time my car left me stranded so far is when that plastic piece busted open, retarded. |
