rod bearing question
PostPosted: Sat Sep 24, 2005 1:24 pm    Post subject: rod bearing question Reply with quote
K I was looking at my extra bearings & couldnt figure it out.
one bearing has a hole in the center & another bearing doesnt.
Question is: .. . which bearing goes in the rod end & which
bearing bearing goes in the rod cap end. Haynes doesnt tell
me anything. Can some knowledgeable wizard show me the light
at the end of the tunnel.. please.
PostPosted: Sat Sep 24, 2005 9:36 pm    Post subject: Reply with quote
Not tooo long ago there was a discussion about oil squirters in the rods. If yours has them,you should find a hole drilled in each rod. -So the bearings with the holes should go on the upper rod end and those without go with the caps.
