wheel specs
yOnKiNaToR
PostPosted: Wed Nov 07, 2001 9:50 am    Post subject: Reply with quote
what is the stock size tires on my '88 924S? i have 195/60/15's on their right now but i heard stock was 195/65/15...also, what is the widest tire i can fit on there without rubbing the fender and suspension and not having to roll the fenders? i'm considering 17's for the wheel size. i want good handling and lighter wheels than stock so if i could fit like 215 or 225's on there it would be great.
PostPosted: Wed Nov 07, 2001 11:08 pm    Post subject: Reply with quote
Your post points out an obvious fact.....you don't know how tire sizes work. But you won't know unless someone tells you so here is how it works. P195/60/15R P-passenger vehicle 195 is the WIDTH in milimeters of that 195mm 60% of that is the height from the rim. 15" rim R radial tire.
Vince Ponz
PostPosted: Thu Nov 08, 2001 12:17 am    Post subject: Reply with quote
205 front and 215 back seems fair 60,55,50 series
yOnKiNaToR
PostPosted: Fri Nov 09, 2001 2:20 pm    Post subject: Reply with quote
195 is width
60 is percent of 195
and 15 is how big wheel is
umm...i know that but what does it prove? and it doesn't answer my question.
Pat
PostPosted: Sat Nov 10, 2001 5:46 am    Post subject: Reply with quote
If you want lighter wheels then stock going with a bigger diameter isn't going to help unless you buy a set of sparse looking alloys. Your also going to have to buy more expensive low profile tires to fit, and unless you race the car the harsher ride isn't goingto be very comfortable especially if you plan to stiffen or lower the suspension
yOnKiNaToR
PostPosted: Sat Nov 10, 2001 10:06 am    Post subject: Reply with quote
i want to maintain the same size tire/wheel combination. and yes, you can get 16-17's that are lighter than stock usually. also, is it recommended to get bigger tires on back b/c my car seems to sway at higher speeds and i want more stability.
