Overheating... What are I missing?
SprintStar
PostPosted: Fri Nov 12, 2004 8:58 pm    Post subject: Overheating... What are I missing? Reply with quote
New thermostat, no thermostat, new headgasket, top end rebuild. The water system is tight. I pressurized it to 20psi and it held.
But after driving around a while, the water boils. Why?
If it helps any, I converted to a 944 water tank while doing the rebuild.
Thanks for any help.
Sprint.
PostPosted: Sat Nov 13, 2004 12:21 am    Post subject: Reply with quote
Did you bleed the cooling system? Is the waterpump leaking, could be bad? Do the fans work? How quickly does it get to the 1st mark if just idling? Can you see it drop after it does, when the t-stat opens?
PostPosted: Sat Nov 13, 2004 12:26 am    Post subject: Reply with quote
Another possible problem, how clean is the radiator inside? Feel for hot or cold spots, you might need to flush it out, may even need to remove it and have it cleaned (rodded out).
PostPosted: Sat Nov 13, 2004 6:25 am    Post subject: Reply with quote
And - Don't even bother trying it without a thermostat installed. Due to the path the coolant takes, you need a good thermostat of the correct type with the extra disc at the bottom. -And running with a thermostat without the disc is equivalent to going with no thermostat at all because to direct the flow correctly, when the thermostat opens that disc has to move down and seal the lower passage of the thermostat housing to direct the flow through the radiator. If that lower passage isn't blocked, the path of least resistance is directly down to the water pump and back through the engine without going through the radiator.
the thermostat should look like this -
dpw928
PostPosted: Sat Nov 13, 2004 12:50 pm    Post subject: Reply with quote
An often overlooked source of overheating is due to the y shaped pipe being plugged. This pipe runs from the front of the head, back to the heater valve and y's off as a bypass to the head. If plugged, it can cause poor or no circulation of coolant to the head.
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
