Check out my rebuilt turbo
Goto page 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
TajMan
PostPosted: Tue Nov 02, 2004 9:28 am    Post subject: Check out my rebuilt turbo Reply with quote
I just got the turbo rebuilt on my '81 931. The thing looked pretty bad when I took it out and it was completely frozen up, wouldn't spin. Now it looks brand new and spins freely with no shaft play whatsoever! I was very impressed. Cost $265 from a place called Hardline Turbo in Salt Lake City, Utah. Was that a good price? Here are some pics:
Bad heat shield that had to be replaced:
Check out the surprise I got when I took the main exhaust off. The cat had been hacked open on the top and completely gutted, then patched and welded back together. Now I need a new one to pass emissions.
'87 924 S
numbbers
PostPosted: Tue Nov 02, 2004 10:50 am    Post subject: Reply with quote
As long as your cat passes the visual inspection, you will probably not have any problem passing emissions. These cars run very clean.
Also, $265 is a very good deal on a turbo rebuild. Most run $500 or more.
PostPosted: Tue Nov 02, 2004 12:47 pm    Post subject: Reply with quote
Yes for 265.00 thats very nice well worth it..
yea thats a old trick gutting the cat before goin to a full flow
and just omitting the cat altogether if you dont have
emissions to worry about.
jpab924
Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
PostPosted: Tue Nov 02, 2004 1:39 pm    Post subject: Reply with quote
Looks like new! Decent price too.
I`ll take the heatshield thats laying between the cat and wastgage pipe pic if you don`t want it. Yes, I am serious. I really do need one of those...oh wait, I thought this was the parts for sale forum...oops.
TajMan
PostPosted: Tue Nov 02, 2004 4:05 pm    Post subject: Reply with quote
You honestly think I could pass with no cat at all!!! I can't believe that, I know a couple of the emissions they check for would pass, but I know some of them wouldn't. The cat really does do something, no matter how clean and well tuned an engine ran there are some emissions that would be there and not pass without a cat.
As for that heat shield sorry, I think I want to put it back on the car.
I need a couple things before I can put the car back together, two critical things are: a new rubber o-ring seal gasket between the upper intake pipe and the throttle body (note its an '81 not an early turbo with the rubber coupling and hose clamps), and a new recessed gasket between the turbo and the downpipe/cat piece (mine is the 3rd revision of the turbo/manifold that uses the recessed gaskets all around). What's the best place to get these? Do I have to go to the Porsche dealership and what are they going to charge?
'87 924 S
kaffine
PostPosted: Tue Nov 02, 2004 4:27 pm    Post subject: Reply with quote
Do you know what the smog standards are where you live? What the allowable CO, HC, values are and what else they check?
80 931
The best desciption of an atom boils down to something unknown is doing we don't know what.
Sir Arthur Eddington
TajMan
PostPosted: Wed Nov 03, 2004 2:50 am    Post subject: Reply with quote
They measure HC, CO, NOx.
I've looked all over but I can't find the acceptable levels for each. I know ours aren't as bad as california emissions, but they're not easy either. I'd say they're in between cali emissions and another state thats about in the middle of the scale.
'87 924 S
PostPosted: Wed Nov 03, 2004 3:53 am    Post subject: Reply with quote
For the seals you reference, I'd suggest trying Jason at Paragon; I've gotten them from my more local supplier, but they don't like to bother dealing with shipping out parts - however, Jason should be just as able to get the parts.
PostPosted: Wed Nov 03, 2004 3:57 am    Post subject: Reply with quote
Mine's been able to pass in NJ. It's always a close call on NOx and actually took a few tries this year, but it does get through with a hollow cat.
CMXXXI
PostPosted: Wed Nov 03, 2004 4:08 am    Post subject: Reply with quote
TajMan wrote:
...new recessed gasket between the turbo and the downpipe/cat piece...
I'm not sure which one you are talking about. There is a large metal sealing ring between the turbo and the exhaust pipe (944.111.205.02) and a smaller sealing ring between the turbo and the exhaust manifold (993.111.195.00). The same smaller ring is also used between the manifold and the J-Tube. The larger one cost me $26.06 a year ago, and the smaller one went for $16.14. These are probably going to be dealership only items.
Great price on the rebuild, by the way. What sort of warranty did they give you? I'm writing that address down for future reference. Got a phone number for them you can share?
'79 Eurospec 931
TajMan
PostPosted: Wed Nov 03, 2004 6:10 am    Post subject: Reply with quote
HLT website: http://www.softcom.net/users/hlturbo/2/
There's a phone number in there but they never answered when I called. I think it was just a Vietnamese family, home based business. I just dropped the turbo off in their box outside the house and picked it up when they said it was done, contact through e-mail. I saw a bunch of turbos on a shelf in their garage but I didn't look around for other machines. I don't know if they did everything there or if they outsource stuff. It was fully balanced and it comes with a 6 month 10,000 mile warranty.
As for the emissions I just pulled out the inspection sheet from our '94 oldsmobile silhouette minivan that we just registered. It lists HC, CO, and CO2 on the sheet but I am almost positive they test for NOx too, I read it on the internet and I've remembered them testing for it before.
The sheet says (for 2,500 rpm test):
HC(ppm) standard is 220 (our minivan only put out 8 )
CO% standard is 120 (our minivan put out .01)
CO2% (it just said the % was 15)
I have a friend who owns a mechanic shop where they do the tests. He can't cheat for me and pass it anyway, but he'll just plug the computer in and test the emissions for free to let me know if I'll pass or not. I'll have to see but I think its going to be a close call, barely not passing the NOx.
Turns out I don't need that exhaust seal, I just found the old one and can re-use it.
I'll try Paragon for that intake seal. The only other things I need to get the car running are (if anyone can help or will sell me some used parts):
Lower radiator hose
brake power booster
air filter (I'll get a K&N at autozone)
2 new tires (I'll get some snow tires cause its already snowing here)
What do you suggest I do to the fuel system if the car ran before it was parked but has been sitting for like 3-4 years.?
'87 924 S
CMXXXI
PostPosted: Wed Nov 03, 2004 9:29 am    Post subject: Reply with quote
I recommend getting as much fuel out of the entire system as you can before you attempt to start the engine.
Drain the fuel tank. Pull in-tank pump. Pour in some gas to wash out any/all crud that has accumulated down by the in-tank pump. Reach into the hole where the pump goes with whatever you can to clean the "sump" where the pump lives. Clean the strainer on in-tank pump, replace in-tank pump. Put in 3-4 gallons new gas and 1/2 bottle of Techron additive or other fuel system cleaner.
Disconnect fuel feed line at the fuel distributor and put the end in an empty container. Jumper your fuel pump relay and let the pump push about a gallon or so of fuel through the system to flush it.
Then, replace the fuel filter. Jumper the relay again to flush anything that may have dislodged when you replaced the filter. Pull your injectors and push some cleaner through them with compressed air to flush them and check their pattern (replace if necessary). Hook everything back up and see if it will fire up. Unless you have a CIS test gauge, you can't validate the Control Pressure Regulator. After sitting for the 2-3 years, it's quite possible (or even likely) that it has gumme up or otherwise gone bad. Can't tell without the gauge, but won't hurt anything if it is bad - things just won't work properly...
Sounds like you are almost there. Best of luck and keep us in the loop!
'79 Eurospec 931
numbbers
PostPosted: Wed Nov 03, 2004 11:28 am    Post subject: Reply with quote
Make sure you have the car as hot as you can get it before the emissions test, and change the oil put Mobil-1 in it. The heat will help the NOX test, and the Mobil-1 will help the hydrocarbons.
PostPosted: Wed Nov 03, 2004 11:33 am    Post subject: Reply with quote
Mine always flunked with no CAT and premium fuel.
Mine always passed with no CAT and regular fuel.
I have collector plates on it now, NO MORE SMOG CHECKS!!!
TajMan
PostPosted: Wed Nov 03, 2004 11:47 am    Post subject: Reply with quote
Thats very interesting. You have a 931 right? Do these cars pull timing if they sense knock from low octane fuel? (I know a lot about how all that works on turbo mitsubishi eclipses and 3000GT's, but they are a lot newer and have advanced computer stuff, I didn't think the '81 porsche could do all that.) Also what year is yours? They changed from mechanical to hybrid to straight electric timing advance during the years they produced the 931 didn't they? Would that have a bearing?
I know to have the car as hot as possible before the test, but I thought that was just to make the cat as hot as possible, it works better that way. Does it still have an effect if you have no cat?
'87 924 S
Page 1 of 10
