augidog
Posted: Sun Jan 18, 2004 2:11 am Post subject: Throttle body upgrade |
I just ran across this on 924
http://www.924.org/techsection/1engine.htm
Has anyone done the Throttle body upgrade from an Audi?
Is it worth it?
Which model,Year,did you take it from?
I'm looking to enlarge the secondary for a little kick when flooring the pedal. _________________ 1978 924 95 mile daily driver.
Audi TB/POR174M/High Flow Cat/2.25" exhaust
I knew that positive thinking thing wouldn't work. |
Posted: Sun Jan 18, 2004 2:17 am Post subject: |
Joe did it at 1 time, i didn't bother, however I have aquired an Weber redline throttle body i am going to be installing soon _________________ 3 928s, |
Mikri184
Joined: 12 Sep 2003 Posts: 746 Location: Ferndale, WA
Posted: Sun Jan 18, 2004 3:44 am Post subject: Throttle body |
I got one from a audi 5000 87. Definitely bigger can't say I noticed a big difference though. I here the weber or 944 upgrade is better. You can also use the throttle body fromm a a-2 GTI as they are CIS as well. _________________ Life is to short to be looking for something? |
Eturbo924
Joined: 09 Nov 2002 Posts: 2212 Location: Londonderry NH
Posted: Sun Jan 18, 2004 3:59 am Post subject: |
I have done both a VW upgrade and the mid 80s-early 90s audi upgrade. look for the ones with the small side vacuume line. Look at my site and likely you will see what I mean.
I have a performance cam and ported/polished head and intake. I had very little time with the actual stock throttle body before I upgraded to the larger one. Can not say I noted a large increase due to a throttle body. What it does seem to do is bog the engine a bit if you go full throttle at low rpms. Others have said this makes no sence but in my car... that is what happens. Though if you can control your enthusiasm and put say 90% throttle until 5000 rpms it rewards you with a rush up to 6000+ when you give it that extra little push.
I am sure some of this can be adjusted with the amount you adjust your pedal position to throttle opening.
Anyway you can see my project at my site. I am working on the other engine now. Well part of it.
Note this. If you have done nothing but the throttle body upgrade you will see no power increase. You can also read this at my site by taking the link below and going to 924 power tricks link on the left. It outlines that nothing can really be increased until you get better head flow.
Eric
www.geocities.com/eturbo924 _________________ 1982 924
1992 968
2003 C4S
Parts Parts Parts and More parts.
E-mail me for parts you need!
Drive Fast! |
Posted: Sun Jan 18, 2004 6:14 am Post subject: |
Yup been there done that. Though I ultimately
got a used redline single throat racen tb
from back east. I will not go back. The
audi will help some. You will be pressed
to feel the difference. Though its there.
Why bother unless its a money
thing. Thats OK.
The redline will blow it out of the water.
Get the 2nd upgrade the after market tb.
There under 200.00
I even polished my audi up before
Jpab gave me the redline. The
redline kicks ass. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
jpab924
Joined: 03 Nov 2002 Posts: 1538 Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
Posted: Tue Jan 20, 2004 2:36 pm Post subject: |
| Hey! I want it back...I`ll trade you a weber carb setup for it. Naw just kidding. |
Posted: Tue Jan 20, 2004 5:58 pm Post subject: |
You never ran it either. Youll never know its
punch.You gonna drive a porsche this spring
Jpab. Are you maken progress. So how the hell
is it goin Jpab.  _________________ 1979 porsche 924 Na
Posted: Sat Jul 11, 2015 3:28 pm Post subject: |
"Big bore" throttle body cross reference:
Neuspeed 3-65.10.xx
Audi 5000 85, 86 non turbo
VW Fox 91 -93
VW Cabrolet 91 -93
VW Golf MK2 8v _________________ erstwhile owner of just about every 924 variant ever made |
Spliffy
Joined: 23 Jun 2009 Posts: 50 Location: North Devon England
Posted: Sun Jul 12, 2015 5:48 am Post subject: |
Got the Audi body on Sunny and believe it does make a differance, particularly on full throtle. Not sure how it would be on a US spec car though. _________________ 1983 N/A
Turbo front brakes
Teledials
Audi T/B
Flush fit screen |
