Charge cooler in CGT intercooler position?
Rich H
PostPosted: Sun Oct 18, 2009 6:41 am    Post subject: Reply with quote
Knew that was coming.... Stand by...
Rich H
PostPosted: Sun Oct 18, 2009 6:47 am    Post subject: Reply with quote
First is looking through the core in the direction of the airflow, second is the top view (If you hadn't worked it out!)
TurboBullet
PostPosted: Sun Oct 18, 2009 9:17 am    Post subject: Reply with quote
I started on this a while ago but other projects and life have gotten in the way...I have all the pieces cut and ready to weld for completion!
87 Porshe 924s custom widebody
Rich H
PostPosted: Mon Oct 19, 2009 4:56 am    Post subject: Reply with quote
Ordered some brass and solid rivets.
Plan is to use the rivets for mechanical strength and the solder the joints for the air seals.
We'll see how I get on...
ic932
PostPosted: Mon Oct 19, 2009 7:38 am    Post subject: Reply with quote
I can only take "strictly bolt-on" to mean that you feel there is some sort of re-sale factor involved, hence the reluctance to cut sheet metal?
I think that this is quite noble, but unless you cop the cost for a genuine CGT IC then you would be better off leaving it stock. If you want to increase the HP then intercool it properly or not at all. I sold a 951IC for £25 the other week so it's peanuts really...
The power level of 177bhp will always be a disapointment in a chassis that Porsche squeezed 350+bhp out of. I find the 211bhp of the 944S2's that I'm playing with at the moment are under powered and in need of some FI. The CGT was only rated at 220bhp with turbo lag...not that impressive really...especially when you drive this chassis at this power level on a day to day...Ask Creenen as a 951 owner.....?
I don't like to be negative but it's as cheap as chips to to it right anyway.. I can't see that you are saving any money whatsoever with this approach and there is no real re-sale value to worry about. In fact, a well done IC job will help re-sale because most potential future 931 buyers will know of the IC's importance not only in terms of extra power but lower charge temps = reliability/longevity.
Btw, I have a new unused 937 wastegate core, and all the parts to re-build it...open to offers.
ic932
PostPosted: Mon Oct 19, 2009 7:41 am    Post subject: Reply with quote
Hey, good work. I'd like ask your opinion on the custom inlet work if thats ok?
PostPosted: Mon Oct 19, 2009 10:28 am    Post subject: Reply with quote
Interesting setup! I looked at those pics a couple days ago, then looked again just now and noticed its an intercooler!
IC932, how would there be any turbo lag on a cgt, with the top mount the lag shouldn't be more than a stock 931. I would expect full boost of <18psi by 4000rpmi max.
PostPosted: Mon Oct 19, 2009 1:41 pm    Post subject: Reply with quote
I think he means that it is not an "instant" 220 Hp or whatever, it takes some time for the turbo to spool up. That is commonly referred to as "turbo lag" and is an inherent trait of turbochargers, weather or not the system is intercooled and the volume of any plumbing. Wherever there is a turbo there will be some turbo lag between idle and full power. Not an issue on aircraft, marine or stationary & industrial engines, less on full drag cars or circle racers but a major concern in a street car.
From Wikipedia:
http://en.wikipedia.org/wiki/Turbo_lag#Turbo_Lag
Turbo Lag
The time required to bring the turbo up to a speed where it can function effectively is called turbo lag. This is noticed as a hesitation in throttle response when coming off idle. This is symptomatic of the time taken for the exhaust system driving the turbine to come to high pressure and for the turbine rotor to overcome its rotational inertia and reach the speed necessary to supply boost pressure. The directly-driven compressor in a supercharger does not suffer from this problem. (Centrifugal superchargers do not build boost at low RPMs as a positive displacement supercharger will). Conversely on light loads or at low RPM a turbocharger supplies less boost and the engine acts like a naturally aspirated engine.
The length of any intercooler plumbing is of minor concern and essentially irrelevant. Calculate the volume of the plumbing, in litres, and then the engine displacement and RPM to arrive at how many mS it takes to fill the volume at a particular RPM. Remember the plumbing and IC already contains air at up to 1 bar absolute. The additional few litres of air required is compressed while the turbo accelerates to its optimal RPM and pressure, having an overall negligible additional delay.
The CGT intercooler is grossly thermally inefficient due to its mounting location. A short pipe run in this case makes extremely little, if any, difference. Porsche learns by their mistakes and progressed to a superior FMIC for the 951. As do owners of modified RX7s and Subies that upgrade to FMICs.
Rich H
PostPosted: Mon Oct 19, 2009 5:57 pm    Post subject: Reply with quote
Yes re-sale is the idea, ther are few enough unmolested 924 Turbos out there as it is. This car is almost totally original, only the wiring has been hacked about (Being rectified slowly) and the paint is a bit of a mess but find me another 932 with no sunroof and manual windows...
As I stated above this is a technical challenge, also no one knows how efficient or otherwise this will be - it might be awesome...
Power isn't the goal either really, my car is 18 bhp down on factory which has a rebuilt turbo and block so is annoying, but the WG hasn't been touched - hence why I have one coming from Dan for rebuild.
Rich
PostPosted: Mon Oct 19, 2009 10:34 pm    Post subject: Reply with quote
Hiya Rich - it is noble to try and keep your 924T in standard/or easily returned to standard condition and I applaud you for it. God knows there are hardly any unmolested ones left. Most of us have cut and changed things over the years, and I'm guessing that some day they will be like 914s are now - short supply of original ones and worth something. Though I wouldn't hold my breath waiting either>
There is plenty of room to mount a FMIC in front of the radiator providing you get your piping right without having to necessarily cut anything.
Andial are the only people to my knowledge who have the wastegate rubbers at around $60 US from memory. However the wastegate springs are available from lots of places in the US. Try Automotion. They are afterall 930 parts. Check ads in Excellence or PW911 for leads.
Make sure you lap in the wastegate valve well (super hardened seat) and you'll almost certainly find the walls on the wastegate scored by the sideways movement of the spring. Just clean up, rebuild and good to go. Helpful to have a big mate push down on assembly (held in vice) while you button up the six studs - you'll see what I mean, particularly with a 1 bar spring.
Rich H
PostPosted: Tue Oct 20, 2009 12:20 am    Post subject: Reply with quote
Tell you what then I'll measure up and see if I can fit one in. Would be easier in the long run I suppose...
Still going to have a crack at the charge cooler bit anyway, it's going to stand me around £30 all in so not bad. Also seeing as it's ali, brass and copper I could weigh it in as scrap and make some money back...
It's the pipework for the FMIC that I don't get, it's going to be very tight in there and very messy with routing...
Thanks for the WG rebuild tips, I'll watch out for that!
tuurbo
PostPosted: Tue Oct 20, 2009 12:26 am    Post subject: Reply with quote
You could also use water/methanol injection and keep the chassis in tact.
The other day I took the 931 out for a run, and the water/methanol injection circuit and pump worked just fine. It's been about 2 years now that I've been running this setup and haven't had a failure yet.
Something to consider, even if you install the IC, because you may want to increase the cooling.
I think your goal is (1) bright, because of the resale issue and reliability under hot conditions issue (2) the most enjoyable and pleasurable option you can choose. It may or may not be 'perfect', but making your own intercooler? How cool is that? Very cool, imho. Gives ya a feeling of pride in your accomplishment. That's where it's at dude.
1980 924 turbo, MSD, Meth. Inj, otherwise stock.
Rich H
PostPosted: Tue Oct 20, 2009 1:20 am    Post subject: Reply with quote
That's what I thought.
The other thing is that SWMBO is away playing with fast jets so I'm unsupervised for a couple of weeks so I can work in comfort on the sofa in front of the TV...
Rich H
PostPosted: Thu Oct 22, 2009 9:35 pm    Post subject: Reply with quote
OK discovered a couple of things:- blowtorches can be too hot and modern lead free solder is rubbish!
I have 2 blow torches one MAPP and one propane, the MAPP one has piezo ignition so it the blowtorch of choice but it gets too hot too quick for soldering! It basically boils off the flux and chars the surface of the solder... Propane is better but doesn't like being tilted over too far.
Lead free solder refuses to flow nicely, it just blobs up and falls off. I melted a bit of the original solder and mixed it in and it flows lovely Need to find some nice (highly toxic) lead filled solder....
Top and bottom plates are now on, looks like it's going to be very tight fit with the bonnet and inner wing, but I'll have to wait for the weekend so I can remove the boost tube and check properly. I will definately need to move the pipework to the back edge of the tanks and blank off the lower ports as the foul the cam cover.
Oh and as most of you probably know, when soldering clean clean adn clean again - it makes things much easier...
Need to make some cardboard templates for the rest of the ducting now.
tuurbo
PostPosted: Thu Oct 22, 2009 9:56 pm    Post subject: Reply with quote
So the soldering worked? Refresh my memory - what metals are you soldering?
I'm looking for a project now where I can use this stuff:
http://durafix.com/
A tad pricy though.
Page 3 of 4
