Posted: Sun Feb 22, 2009 1:39 pm Post subject: |
Posted a question over on MazdaWorld, and the reply there was that there doesn't seem to be any or much info available on this particular unit, but that it is similar to (and possibly the same as) the Lysholm 1200 AX. Here are the specs for that unit:
Inlet temperature = 20 C
Displacement = 1.2 l/rev (0.0424 CF/rev)
Built in volume ratio = 1.35
Max rpm = 15 000
Max pressure ratio = 2.2
 _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Thu Apr 30, 2009 5:25 am Post subject: |
Wow, nice find! Thanks for the link, going to the reference bookmarks immediately. _________________ erstwhile owner of just about every 924 variant ever made |
moone924
Joined: 05 Feb 2003 Posts: 868 Location: Douglas Wyoming
Posted: Tue May 26, 2009 10:22 am Post subject: |
Have you found any information on the size of the crankshaft pulley used in the stock madza set-up? Also have you found any info on the wastegate and are you going to be using it ?
I have a wicked idea about using one of these superchargers on a waterboxer in a vanagon syncro. _________________ Ryan Moone
New philosophy : one car project at a time. |
Posted: Tue May 26, 2009 10:31 pm Post subject: |
No, haven't been able to find the info on the crank pulley, but haven't really tried that hard either. Regarding the wastegate, I have the complete wastegate assembly, which you can see bolted to the top in a couple of the photos in the OP.
From what I understand, this unit can produce 21 psi of boost in stock form, and the wastegate is setup to bleed off so that only 14 psi is produced. The article Roger linked to also has some good add'l info on how this was controlled as well. _________________ erstwhile owner of just about every 924 variant ever made |
