J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Tue Apr 22, 2003 5:56 pm Post subject: |
I started on the front of the car yesterday. Took off the front skirt no worries, same with the bumper. things got a little intense with the badge panel. I sanded the two edges where i knew the spot welds were and then drilled them out. But ended up having to do a bit of cutting and pulling and cursing before it came off. I hit so hard with a hammer at one stage the badge popped off.
All those parts looked like they had been pulled off before. the spot welding was at uneven intervals and varied at the degree at which it was done. And the type of nuts and washers werent consistant.
The rust on the underside was pretty bad and under the left headlight it had spread to the metal beneath. Also found that altho u cant see at a glance, the badge panel is also bolted to the guards by the headlights.
What i didnt expect is something i should have expected. Bad accident repairs. I knew my car had had an accident on the drivers side. theres crappy bog on the drivers door which looks like it was finished with 80 grit. the door isnt lined up straight and the hinge where it joins the body has been welded as well as bolted on. Also its had a bad respray where the guy didnt even bother removing the aerial to do.
Well i found something else. the seam line between the guards and the badge panel were FAKE! They were roughly 10mm inboard of where they were supposed to be.
Scrapping off the bog, of which on the right side theres was plenty of- about 10mm thick at one point, u'll never guess wot i found. The idiot had welded the guards to the badge panel I was pretty annoyed at that stage and just cut around it.
Then i put my bumper back on so if i needed to drive it in an emergency i could.
the drilled spot welds and underneath the panel- lots of rust forming!
under the left headlight and the exposed welded seam
under the right head light showing more rust, welds and check out that bog! man im glad this car was galvanised, its so humid and wet here anyway it could have been worse!
as it is now
I have a fibreglass replacement going in soon. have decided i'll get fibreglass guards and bonnet made up too. I wanted a project car, looks like i got it! this is all a steep learning curve.
FOR SALE:
One badge panel. Needs paint. Some assembly required. Best offers?
 _________________ '86 944 |
Posted: Wed Apr 23, 2003 4:21 am Post subject: |
I cut it into 5 pieces to make it fit the narrow 924 &
the front fender opening is smaller also..Its layen in the garage _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
