Stu2j
Joined: 03 Nov 2002 Posts: 1285 Location: Virginia Beach, VA
Posted: Wed Dec 04, 2002 5:40 am Post subject: |
""Good spacers are not cheap, or easily found for the four bolt disc/drum setup.""
It's not that bad. Performance Products has them (the 4 bolt) and I recently found out that it is $22.98 for a pair (not each as I originally thought) and they are about to run another 20% off holiday special.
Another member has offered to sell me some spacers and I'm just waiting to hear if they are 4 bolt. If not, I'll just get them from PP during the sale.
(I may still take them if they are 5 bolt to use on the 924S but the NA really needs them). _________________ -Stu
924 owner since 1988
924S owner since 2002
Click here to view them: |
gohim
Posted: Wed Dec 04, 2002 6:11 am Post subject: |
| The inexpensive spacers sold by PP are flat. They are not "hubcentric" (they don't have the centering flange), they are cast (cast spacers are cheaper), and do not balance as well as the machined spacers). |
924martinirossi
Joined: 04 Nov 2002 Posts: 605 Location: Seattle, Washington, USA
Stu2j
Posted: Thu Dec 05, 2002 3:48 am Post subject: |
| 924martinirossi wrote: | | Pictures of rims I'm selling. They have 215/60/14 Yokohama S306s mounted. They were made for the 924 sometime in 1980. No need for spacers. |
I assume that these will fit the 82 924 without any modification?
Do the tires come with the rims? How much are you asking for the rims, tires (if included) and shipping? _________________ -Stu
Posted: Thu Dec 05, 2002 5:47 am Post subject: |
| Stu2j wrote: | | 924martinirossi wrote: | | Pictures of rims I'm selling. They have 215/60/14 Yokohama S306s mounted. They were made for the 924 sometime in 1980. No need for spacers. |
Do the tires come with the rims? How much are you asking for the rims, tires (if included) and shipping? |
Yes the rims come with tires or so he states if your 82 has the disc/drum then yes these will fit yours _________________ 3 928s, |
Posted: Thu Dec 05, 2002 7:36 am Post subject: |
does anyone have a set of 4-bolt factory or properly built spacers that they could measure the outer diameter of?
The cost of freighting a couple of slabs of metal to here is just not worth it so I figure I'll run one up on a CAD program and get a pair plasma cut. _________________ 1979 924 (Gone to a better place)
924martinirossi
Posted: Thu Dec 05, 2002 9:28 am Post subject: |
They are 4 bolt rims. Don't the 82 have 5 bolt rims?
Michael |
Stu2j
Posted: Thu Dec 05, 2002 9:35 am Post subject: |
>>They are 4 bolt rims. Don't the 82 have 5 bolt rims?""
Nope, my 82 has 4 bolt rims. Front disc, rear drum.
Whatcha looking to get for em? _________________ -Stu
924 turbo
Joined: 02 Nov 2002 Posts: 1566 Location: Simi Valley, CA, USA
Posted: Thu Dec 05, 2002 9:37 am Post subject: |
| 924martinirossi wrote: | | They are 4 bolt rims. Don't the 82 have 5 bolt rims? |
The 924 n/a didn't get 5-bolt brakes as standard ever. _________________ Jon Furst |
Posted: Fri Dec 13, 2002 3:26 pm Post subject: |
Well I have access to 2 high quality aluminum 27 mm 4 lug spacers
with the hump on ther back circle to grip the drum when tightend down
these are not homemade but are from like performance or automotion
Ill post a pic If you want them for a fair price..I got em but those are mine
I have access to another set though I think. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
porschetroy
Posted: Wed Jan 01, 2003 8:13 am Post subject: |
I have a set of four 2" wide 4-bolt spacers for the 924 bolt pattern. If anybody is interested, I can send digital pictures. I got them from a car with the 944 body kit. They are aluminum and hubcentric with the locating recess in the center. They are an 8-hole design which means you bolt them the hub with studs and nuts and then the wheel bolts to the threaded holes in the spacer. This way you don't have to use ridiculously long lug bolts which would flex.
If you're using the 944 fenders, this is the cheap and easy way to get your wheels out to the fenders and use your original wheels. |
