Aftermarket torsion bars..
Goto page Previous  1, 2
PostPosted: Sun Sep 08, 2013 1:36 pm    Post subject: Reply with quote
PostPosted: Sun Sep 08, 2013 1:37 pm    Post subject: Reply with quote
Grenadiers wrote:
Install the 250# springs up front, the sways, and see what happens.
Ha, or you could just ask Dave what happens...when he took this approach he was here complaining about the car pushing.
PostPosted: Sun Sep 08, 2013 10:09 pm    Post subject: Reply with quote
Yeah but. My current car is setup like your race car, slight oversteer. Lowered, lots of negative camber, not as much fun to drive anymore on our country roads. Incredibly fun, though, on the race track. Does he want that?
Kenodog
PostPosted: Sun Sep 08, 2013 11:23 pm    Post subject: Reply with quote
Well we have very, very good roads here. Mostly because we don't usually get much snow so if the car is a bit stiff that's cool. We also tend to drive faster here, there is much less speed enforcement than down south. After some thought, I think I will get the 27mm bars. That will be a bit stiffer than stock and should give me a neutral to slight oversteer car. Thanks for the feedback folks !
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
PostPosted: Mon Sep 09, 2013 12:28 am    Post subject: Reply with quote
27 is a big increase...nearly double the factory rate. You should be happy with it.
On another note, What are your plans for rear bushings? I have some feedback on where to get most bang for the buck.
Kenodog
PostPosted: Mon Sep 09, 2013 12:36 pm    Post subject: Reply with quote
Wow for some reason I thought our cars came with 25mm bars. Just looked on Clarks and it turns out we have 23.5. Ooops. looks like 26mm will do the trick.
Rasta,I have a full set of the black (Weltmeister?) bushings for the torsion bar carrier. Got them with a parts lot we bought somewhere. However, if you have a better suggestion that doesn't cost a mint I'm all ears. Hate to install the freebies just to regret it later.
Thanks guys
1981 931, Sabine
2024 KLX300
2024 KLX140
Brockoli
PostPosted: Sat Oct 05, 2013 6:32 am    Post subject: Reply with quote
I have 250# springs up front and the stock 23.5mm t-bars. Front sway 23mm rear 19mm 3 way adjustable (set to the tightest setting). With 205/245 tires and the suggested alignment from the Pasha article.
I find it does understeer a bit on track in tighter corners but is fairly neutral in faster sweeping corners. I messed with tire pressures a bit and it helped get rid of a little understeer.
I plan on doing the t-bars one day and going with a bigger front sway bar to finish the suspension as suggested in that article.
'80 924 M471,Wideband O2, Full coilover susp,23/19 sways,Bilstiens,KLA Strut Brace,Roll Bar,Test Pipe,BBS RS, Willwood BBK
25% of a '87 944 Chumpcar http://straightpipe.ca/forums/showthread.php?t=2454
'79 924 Sebring Edition(Sitting)
Page 2 of 2
