Aerodynamics
924_fan
PostPosted: Tue Jul 30, 2002 10:10 am    Post subject: Reply with quote
I believe that a belly pan did come with some of the 924 models. It is a one piece panel made of sheet metal. It has a few louvers in it. The pan is attached to the car on the cross member and the valence panel. The 944 pan is made of plastic.
I think that many cars are missing the pan because it must be removed to do anything to the car from underneath. And, lazy mechanics do not replace them.
Pat
PostPosted: Tue Jul 30, 2002 10:18 am    Post subject: Reply with quote
Actually 924's had a slight underbody aerodynamic aid, the belly pan. You know, the one every-one rips off so you dont have to wrestle it off whenever your under the car. The big changes in the 951 where the bottom of the front spoiler met with the belly pan and I think that there was another panel under the gas tank that met with the rear diffuser, also the rocker panel extensions. I dont care if it's aerodynamic it's aesthetic (its purdy!!).
Body Shop Rob
PostPosted: Thu Aug 01, 2002 6:20 am    Post subject: Reply with quote
Michael "924martinirossi" has one of those louvered, metal belly pans in good shape. Its a hard to find item and his is the only one I have ever seen. It seems a crime to bolt it under the car for more abuse.
I don't know if it would make the car more slippery or if it assists cooling the engine compartment. I'd like to use it as a template to make one for my car, so I'll talk to him about that. Also, I'll take a picture of it and post it.
BSR
924_fan
PostPosted: Thu Aug 01, 2002 8:18 am    Post subject: Reply with quote
That sounds like it's the same as the one on my car.
dwak
PostPosted: Thu Aug 01, 2002 11:19 am    Post subject: Reply with quote
I have one of those belly pans lying around but it's butt ugly so I'll probably Ebay it.
dwak
John H
PostPosted: Thu Aug 01, 2002 3:49 pm    Post subject: Reply with quote
If you've got a belly pan you should reinstall it. The pan is part of the cooling system and the car runs cooler with the pan.
I've raced my car for many years and when ever we raced the car with out the pan it runs slightly hotter.
The 924 had a pan that fastened to the front and to the cross member and then had a couple of ears at the sides to bolt ot the cahssis rails behind the sway bar mounts. The 944 pan that I run now is an alloy version and doesn't have the ears that bolt on to the chassis rails.
[ This Message was edited by: john h on 2002-08-01 15:50 ]
steve
PostPosted: Fri Aug 02, 2002 12:49 am    Post subject: Reply with quote
can someone that has one of these pans please take a pic of it and post it. i'm interested to see what they look like
Cbass
PostPosted: Fri Aug 02, 2002 7:00 am    Post subject: Reply with quote
Hey John, do you think a 944 pan would fit on a regular non GT 924? I'm just thinking without having to weld any extra metal on, but cutting is fine.
John H
PostPosted: Fri Aug 02, 2002 10:45 am    Post subject: Reply with quote
The 944 seems to fit onto a standard 924 ok - You might have to make a couple of little brackets at the front.
My steel unit is a normal 924 unit and it fits on the GT without mods. The 944 one fitted and mounted to the same holes - no cutting or welding required.
[ This Message was edited by: john h on 2002-08-02 10:45 ]
eturbo924
PostPosted: Fri Aug 02, 2002 10:22 pm    Post subject: Reply with quote
The 944 unit is different. First it is AL not steel and also the front mounting points are differnt. I think it has to do with the differnt style of the sway bars on the cars. Anyway you can cut and bend the AL pan easy and make it fit. I did. With a couple small cuts and bends the pan mounts right to the studs that hold my front sway bar. I will take a photo soon.
Eric
Diesel
PostPosted: Sat Aug 03, 2002 5:07 am    Post subject: Reply with quote
I bought one from , I believe, Lars a while back. A real good price BTW. I put it up and I don't see any difference in cooling. However, that's not why I wanted one. You should have one on to keep debris away fron the timing belt area. Plus it looks nice when you open the hood and look down.
GP510
PostPosted: Sat Aug 03, 2002 7:17 am    Post subject: Reply with quote
The undertray on my '87 924S is metal. I can't remember if its steel or aluminum. I will have to check. It will be easy considering its on a shelf in the garage. I took it off to work on the car and misplaced all the bolts that hold it on. Seems like it was aluminum, but I will get out the magnet and check.
Bart
'87 924S
PORSCHEV
PostPosted: Sat Aug 03, 2002 11:08 am    Post subject: Reply with quote
I have one as well .... not all banged up. I plan to insatll it when the project is finished. I also though it would help cool the engine conpartment.
dwak
PostPosted: Sun Aug 04, 2002 4:41 am    Post subject: Reply with quote
I guess in terms of aerodynamics, one would want a long clean path on top and a short clean path underneath for max lift downward. Like a sail/airfoil.
dwak
GP510
PostPosted: Sun Aug 04, 2002 5:40 am    Post subject: Reply with quote
The undertray on my '87 924S is aluminum.
Bart
'87 924S
Page 2 of 3
