Ballast Resistor
Duncan
PostPosted: Fri Feb 01, 2013 2:12 am    Post subject: Reply with quote
Hi Ideola,
I was wondering if you have access to more information than us mortals.
Everybody can access the online catalog and price list, but (to put it mathematically) pricing seems to be a necessary but not sufficient condition for availability.
for instance for the coolant tube I found out that only when the parts dealer ordered it, it turned out to be not available anymore.
Cheers,
Duncan
1983 NA Alpineweiss since 2001
Peugeot 205 Generation
PostPosted: Fri Feb 01, 2013 2:26 am    Post subject: Reply with quote
Just heard back from Porsche. Only two remaining in the U.S. $32 + shipping.
PostPosted: Fri Feb 01, 2013 2:35 am    Post subject: Reply with quote
I signed up as a part dealer in January. Requires a federal tax ID and a state sales tax license here in the U.S. Also costs a monthly subscription fee, so it only makes sense to do it if you have a legitimate business. I make barely enough margin on the OEM parts to cover the monthly fee plus the associated credit card or paypal transaction fees.
I could charge more for the OEM parts, but then I wouldn't be competitive with other online parts dealers. At this point, I just need the subscription to pay for itself, I don't really need it to make money. It is worth it to be able to consolidate my suppliers down to only two for all of the OEM stuff...plus the ease of seeing directly into availability, and being able to handle all ordering online.
The problem with the system is that it is not very accurate on availability. There are parts that show up with pricing, but when you inquire, they are NLA. There are parts that show up as "pricing on request" which more often than not are also NLA, but some of them I know for a fact are still available, they just don't publish the pricing.
So what I have to do is submit a "pricing and availability" check through the online system. The contact who fulfills my order is very responsive online (as you can see from the above example), which is great. No more waiting days and weeks for a call back.
Duncan
Sorry, I was not patient enough
This is what I use to check pricing of parts:
http://www.porsche.com/germany/accessoriesandservices/classic/catalogue/spareandexchange/default.ashx
Mudd
PostPosted: Fri Feb 01, 2013 3:09 am    Post subject: Reply with quote
Ideola, according to Daniel Berwind at Jim Ellis part number 052 is round in shape. Can you tell if it is the same ohm value as the rectangular one on my car. The shape is irrelevant as long as the ohms are the same.
1,8 is stamped on mine, I assume that is the ohm rate.
Thanks.
1987 944
PostPosted: Fri Feb 01, 2013 3:23 am    Post subject: Reply with quote
Thanks.
I don't know of any way to confirm that, as those kinds of detailed specs are not in PET or FSM. Since there are only two in the country, it will be difficult to even look at one.
PostPosted: Fri Feb 01, 2013 3:33 am    Post subject: Reply with quote
Interesting. That lookup tool is not available on the US or UK sites. I tried plugging in some numbers, however, and I don't get anything back. What format do you use for the part numbers???
Duncan
PostPosted: Fri Feb 01, 2013 5:31 am    Post subject: Reply with quote
Just the number without spaces
477905052A VORWIDERSTAND 18,73 €
That is without VAT @20%
So with VAT that is less than $20
PostPosted: Fri Feb 01, 2013 5:53 am    Post subject: Reply with quote
Actually, if it's 18,73 € that is equal to $25.43 in USD, not including whatever VAT and freight charges might have been added to get the two remaining parts over here to the US...
The currency issue is probably one of the reasons the parts search is not enabled outside of Germany.
Duncan
PostPosted: Fri Feb 01, 2013 6:00 am    Post subject: Reply with quote
You are completely right , I did the conversion the wrong way
it is 19*1.20*1.30=30. Long day at the office.....
In conversion from US$ to euro, the VAT and the $ to € cancel roughly.
PostPosted: Fri Feb 01, 2013 12:23 pm    Post subject: Reply with quote
Beru Resistors with wires disconnected an ohm reading was Resistor A=2.4ohm
B=2.4ohm
Type:Beru wz18-2f
http://www.ferrarichat.com/forum/technical-q/297239-308-ignition-module-2.html
Mudd
PostPosted: Sat Feb 02, 2013 12:37 am    Post subject: Reply with quote
Ideola and Paul, I followed the links in Paul's post and it took me to an exact match for my resistor. It was like seeing an old friend. I purchased it from seekpart24. Ideola I was not convinced that the part you found was the same as what I needed. I would much rather buy parts from you because of your participation and help on this board but I wasen't sure you were talking about the correct part.
I find it hard to believe that more early 924s aren't having this same resistor going bad. Mine looked like it exploded and caught on fire after only 18,000 miles. It took me 4 or 5 hours on the computer to locate the part and still don't have it in hand. I expect an e-mail anytime explaining that the part is NLA even though my money has allready been taken out of my account. I will report back if I get the correct part or not.
1987 944
Kens_74_911s
PostPosted: Sat Feb 02, 2013 4:41 am    Post subject: resistor Reply with quote
Ohms confirmed 1.8 just removed from the inside firewall 82 924 with AC it runs the fan at low speed. I think I have 2 of these. $15 ea shipped in US. They are the same as a early =<85 944.
85.5 944 and up up ran a dual set on an aluminum bracket. They ohm out at 1 ohm ea.
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s widebody
96 BMW 750iL
99 BMW 328i
81 VW MK1-1.8 GTI, 5 spd Pickup
02 Explorer (wife's)
92 BMW 735iL Parting
84,85,86x3,87,944. 82-924,88-924s parted
68, 70, 72, 73, 911~ 70,73 914 past Pcars
Mudd
PostPosted: Sat Feb 02, 2013 7:18 am    Post subject: Reply with quote
This is the one I bought. Identical to the original.
But more importantly I finally figure out how to post pictures.
1987 944
PostPosted: Sat Feb 02, 2013 3:41 pm    Post subject: Reply with quote
Win-Win
1981 924 Turbo sold
1982 924 Turbo sold
Page 2 of 3
