How can I mount this intercooler?
Goto page Previous  1, 2
PostPosted: Thu Jul 12, 2012 6:45 pm    Post subject: Reply with quote
just means to match the openings, won't need to if replacing the manifold as it is already round.
PostPosted: Thu Jul 12, 2012 9:42 pm    Post subject: Reply with quote
I found the plug/pigtail, are you ordering anything from Dan?
JasonO
PostPosted: Fri Jul 13, 2012 7:14 am    Post subject: Reply with quote
Yes most likley in the next week or so.
john h
PostPosted: Mon Aug 13, 2012 2:06 pm    Post subject: Reply with quote
That was one of my intercoolers and I was originally mounted on a Series II, I got it back and then on sold it to Jae and obviously it went with his car to Invercargill.
From memory you can stretch a bit of silicone tubing over the intecooler outlet and hose clamp it and then clamp the other end to the throttle body.
I
JasonO
PostPosted: Mon Aug 13, 2012 4:29 pm    Post subject: Reply with quote
Hey John thanks for that,putting two & two together I took a guess that you made this!. I've ordered some parts to convert over to the round throttle body and are in transit at the moment so I may just look at sorting it all out in one go (hopefully).If for any reason I run into failure ill take a shot with what you suggest.Did a quick install of a boost gauge today and car is running at 12PSI so I'd like to get that inter-cooler on asap,Cheers.
JasonO
PostPosted: Tue Aug 14, 2012 4:49 pm    Post subject: Reply with quote
throttle body seal kit arrived today big thanks to Ideola & Grenadiers for supplying these items to me!,Both happy and surprised to see good instructions supplied. I like this sticker but if it was clear and a higher quality it would likely go on my car for sure,just food for thought.
Page 2 of 2
