Posted: Wed Mar 24, 2010 12:42 am Post subject: |
| morghen wrote: | | the ALU trailing arms are MUCH lighter than the 5x130 steel trailing arms. |
Just held them both. . .not convinced. _________________ Toofah King Bad
Joined: 10 Dec 2006 Posts: 981 Location: Noosa Heads QLD Australia
Posted: Wed Mar 24, 2010 1:09 am Post subject: |
Yeah, now what about the trailing arms?  _________________ 80/81 932/8 ROW |
Posted: Wed Mar 24, 2010 1:56 am Post subject: |
peter? I weighed the entire trailing arm assemblies with brake hardware included. So we have an aluminum arm with disc brakes and a steel arm with drum brakes, I found 4 lbs difference.
I just didn't have a steel trailing arm with disc brakes to weigh, or I'd have had a measurement for that as well. Maybe Rasta has one I can borrow for a quick scaling. _________________ Stefan
Khal
Joined: 26 Sep 2003 Posts: 4872 Location: Sunny and lovely interior BC, Canada
Posted: Wed Mar 24, 2010 3:59 am Post subject: |
| fiat22turbo wrote: | | All measured by my bathroom scale, so accuracy is not guaranteed. |
No, I'd imagine not!
But if you're saying one is relatively heavier than the other, I have no problem with that. And by up to 10%? Wow, that is surprising. Although the '76 toofah is possibly up to 14% lighter than an '88 824S. I guess that weight difference has to come from somewhere... _________________ '80 924 Turbo |
Posted: Wed Mar 24, 2010 4:42 am Post subject: |
Well, I stepped on the scale about 2 months ago before I started on a health regimen and it said 215, now it says 200lbs and I've tightened my belt another notch.
I did actually test it and calibrate it some a while back with some dumbbell weights and it was fairly accurate to what the weights were rated at. I'd trust it to at least 1lb +/- _________________ Stefan
ic932
Posted: Wed Mar 24, 2010 5:23 am Post subject: |
| peterld wrote: | Yeah, now what about the trailing arms?  |
Aussie humour Peter? I wondered what Rasta had just held, and wasn't convinced about too lol
Just kidding... |
Posted: Wed Mar 24, 2010 10:26 am Post subject: |
| fiat22turbo wrote: | peter? I weighed the entire trailing arm assemblies with brake hardware included. So we have an aluminum arm with disc brakes and a steel arm with drum brakes, I found 4 lbs difference.
I just didn't have a steel trailing arm with disc brakes to weigh, or I'd have had a measurement for that as well. Maybe Rasta has one I can borrow for a quick scaling. |
I recon there is more than 4 Lbs between a rear drum, shoes, cylinder, back plate & hardware and a disc (rotor), loaded caliper & hardware. Anyone got both handy to compare on the same scales?
You or the missus got any scales in the bathroom Rasta? Realize your personal scales wont go high enough and just weigh grams & points.  |
!tom
Posted: Thu Mar 25, 2010 1:33 am Post subject: |
I've got the parts to do a 5-lug conversion, complete with some beat up steel arms that I'm not intending to use. I'm in no position to weigh the drums though, as they're still on the car.
If nobody does it sooner, I hope to embark on this project this summer and can try to remember to weigh things then. _________________ 78 924 NA
5-lug |
Posted: Thu Mar 25, 2010 1:54 am Post subject: |
You forget about the fact the the disc brakes have an internal drum brake mechanism on top of the large chunk of rotating steel attached to said drum. _________________ Stefan
Posted: Thu Mar 25, 2010 2:04 am Post subject: |
Having lifted and moved complete rear suspension assemblies of both configurations, it sure seemed to me that the steel based versions were heavier. But, perception is NOT reality, and it could have been psychological, so better to stick with empirical facts. Unfortunately, don't have one of either around intact and loose from a car at the moment to verify.
In any event, the guy over on Rennlist with that Sick-as-in-Schweet 944 project posted a verified weight loss document from his project in this thread. Since not everyone here has a Rennlist account, I downloaded the doc and uploaded it to my Google docs repository, which you should all be able to access. Something like this would make a great "collective" project if we could adapt it specifically to the 924. Something I may do when I get a spare moment, and make available for edits to any 924board member with a Google account. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Sat Mar 27, 2010 5:28 am Post subject: |
| !tom wrote: | I've got the parts to do a 5-lug conversion, complete with some beat up steel arms that I'm not intending to use. I'm in no position to weigh the drums though, as they're still on the car.
If nobody does it sooner, I hope to embark on this project this summer and can try to remember to weigh things then. |
If you simply mean the weight of a drum (and I happen to have new) I could do that right now.... _________________ 1980 931 since 1989
!tom
Posted: Sat Mar 27, 2010 6:59 am Post subject: |
That would be helpful, but what people are more interested in is the entire brake assembly; shoes, drum, backing plate, wheel cylinder, etc. vs. disk, shoes, pads, caliper, caliper mount, shield, etc.
My drum brake assembly is still in daily use, and I have yet to dissassemble my disk brake assembly from some beat-up arms. I have everything needed to make this comparison myself except for the time (and shoes), and I plan on making time once I get the remainder of the kit (the shoes) from CBass. _________________ 78 924 NA
5-lug |
Posted: Sat Mar 27, 2010 10:53 am Post subject: |
Personally am keen to know the accurate TOTAL weight difference between a steel arm 5 lug and an ally arm 5 lug.
The more items and figures we get the more benefit for everyone. |
Posted: Mon Mar 29, 2010 6:46 am Post subject: |
I think we all should really start a collective weight thread. Each of us could be editing our own section as we add weighed items both as whole assemblies and as individual parts. I almost wish we could back out of this thread and start a sticky thread of the same title. I am looking at iron engine mount bracket right now in CAD and the properties function is kicking out over 2 kilos! I will actually weigh it of course when I get the chance. seems crazy
Sorry if I hijacked this thread but it is weight data for the collective
Edit adding link:
Performance from Weight Loss (Weight_Loss)
http://www.924board.org/viewtopic.php?t=3648&highlight=headers _________________ 1980 931 since 1989
ic932
Posted: Mon Mar 29, 2010 7:16 am Post subject: |
| Mike9311 wrote: | I think we all should really start a collective weight thread. Each of us could be editing our own section as we add weighed items both as whole assemblies and as individual parts. I almost wish we could back out of this thread and start a sticky thread of the same title. I am looking at iron engine mount bracket right now in CAD and the properties function is kicking out over 2 kilos! I will actually weigh it of course when I get the chance. seems crazy
Sorry if I hijacked this thread but it is weight data for the collective |
Certainly not a hijack, bang on topic lol. Those 924 engine mounts are wrong!
I agree but getting cats to weigh? keep in KG too! A pound increment is to small to worry about. And official weights are metric... |
