Posted: Sun Mar 08, 2009 11:47 pm Post subject: |
sounds like a lot of work for a non race dedicated race car _________________ 1979 NA
my Porsches Arse!!! |
daveo
Posted: Tue Mar 10, 2009 6:28 am Post subject: |
Bass GT have u got any piks of your set up, ind if im not being out of order can u tell me the cost.
my new car is coming on good it was Dave Dennets old car, blew the head gasket on our first test, (been siting for 2 years doing nothing) Dave did say to change it. so might see u out on a sprint some time
Dave |
bass gt
Posted: Tue Mar 10, 2009 7:32 am Post subject: |
Hi Dave,
I do, but they are on a PC in the UK, whilst i'm in SA!!
Price wise, i seem to recall the PACE pump being about £500. Then you need the oil inlet adaptor, the standalone oil filter housing, drive belts and oil tank. Then the cost of modifying the sump. Then a spare bottom cam belt pulley, and finally, a load of JIC -12 and -10 hose and fittings. Don't even think about using push on type.
You will end up spending about £1k to £1.3k doing this. The upper price is if you are going to re condition the engine, such as rings and seals.
Give PACE a call. I dealt with a guy called Neil, but i know he is no longer there. Another point, the pump locates on the stock alternator lug on the block, so you need to relocate the OE alt if this is a turbo motor.
Posted: Wed Mar 11, 2009 1:48 am Post subject: |
FWIW:
| On 23 Apr 2008, Tony @ Pace Products wrote: | The pump and bracket assembly is £507.15
The 38 tooth pump pulley is £56.70
If you require the crank pulley blank that Steve Bassington had the price is £37.00
The 270L075 is £9.00
The oil in assembly is £38.00
These prices are subject to carriage and vat
Our lead time currently is 10 weeks |
Here is the email address I have: tony AT paceproducts DOT co DOT uk _________________ erstwhile owner of just about every 924 variant ever made |
bass gt
Posted: Wed Mar 11, 2009 2:52 am Post subject: |
Dan,
Good post. The one thing i would add is that you don't need the bottom pulley they mention. It's far simpler to use an additional 924 bottom timing pulley as this can be drilled through and mounted onto the cam pully. Then you just need a much longer centre bolt.
Also, as you are in the US, they shouldn't be charging you VAT, as this is a tax applicable to the EU. of course, you will have your import duties to pay. With the Pound/Dollar rate as it is, now is a good ime to buy!!
Also, add on the costof the oil tank, hoses ect. Also, they don't mention the standalone filter housing on the quote
Finally, if you do use the cam pulley, you MUST let PACE know, as the tooth profile is slightly different, and they neeed to machine the pump pulley to suit. They also supply the proper drive belts
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Wed Feb 24, 2010 9:37 am Post subject: |
*bump*
Do you still have pics Steve?
Also, I checked out paces site and theres nothing there for porsches. obviously they do do them though. Would they have a solution for 944's as well? a SFR kit is US$4g + shipping! _________________ '86 944 |
