Weber Redline TB Doco
Goto page Previous  1, 2
PostPosted: Sat Aug 09, 2008 1:53 am    Post subject: Reply with quote
Maybe you / we can find you a SI 931 intake? They should be dime-a-dozen...
Sure. They`re as common here as koalas in gumtrees are in the USA.
Actually a 931 S2 manifold will be much better for this application as it has the large (58mm IIRC) round hole and square bolt pattern. Then you won`t need the adapter and have sufficient room for a bend. Its not a bolt on since the stud hole spacing is different and I understand the ports don`t exactly match. So it requires some port work and drilling/milling of holes. Runner length is no problem and will actually improve torque slightly through the usable midrange.
How thick is that adapter Gav?
Maybe it`s possible to mill the manifold face at an angle to incline the TB so that a bend will fit over the fuel rail. Hood clearance is a big issue but the TB can be rotated (90*) to its lowest edge, that may just fit?
Or of course you can imitate my manifold, hacking out the TB mount area and weld in a larger Aluminium flange, recessed deeper in for additional clearance. Then the TB can be bolted direct, obviously gaining the thickness of the adapter.
Something to think about over the week end.
PostPosted: Sat Aug 09, 2008 2:15 am    Post subject: Reply with quote
Unfortunately, the bolt pattern is much smaller on the Weber than the SII manifold, already checked that. You'd have to have an adapter plate either way, although it could be much smaller with the SII mani. The adapter plate is about 1" thick (from memory) and it is designed to create a smooth transition between the round bore of the TB and the lopsided ovoid audi-style opening on the manifold. Shaving it might muck with the airflow, but I suppose anything is possible...
emoore924
PostPosted: Sat Aug 09, 2008 11:36 am    Post subject: Reply with quote
I have an adapter plate...
PostPosted: Sat Aug 09, 2008 11:49 am    Post subject: Reply with quote
You have a Weber-to-SII adapter plate???
PostPosted: Sat Aug 09, 2008 1:51 pm    Post subject: Reply with quote
Should be a piece of cake to make one from 3/8 or 1/2" ally if its not possible to simply drill and tap 4 holes in the manifold.
emoore924
PostPosted: Tue Aug 12, 2008 1:07 pm    Post subject: Reply with quote
Heh heh. You know how this works. I have one of everything for this car and if you want pickies, please PM.
emoore924
PostPosted: Wed Aug 13, 2008 1:49 pm    Post subject: Reply with quote
Ok, I checked and I have a series I adapter. It is egg-shaped, not round.
Mea culpa
PostPosted: Wed Aug 13, 2008 5:04 pm    Post subject: Reply with quote
I'm looking into a different option now maybe...
Anyone wanna buy a Weber and adaptor plate...
Chrenan
PostPosted: Wed Aug 13, 2008 11:56 pm    Post subject: Reply with quote
Put it on EBay, I got close to $200 for mine when I sold it. Some guy in Denmark must have really wanted it. It almost completely paid for the parts car I pulled it off.
Page 2 of 2
