Boost Gauge
Goto page Previous  1, 2
TroyDest
PostPosted: Tue Apr 16, 2002 7:59 am    Post subject: Reply with quote
Good thinking Smoothie! To check the bypass valve: open the hood with the engine running, crack the throttle quickly and close it quickly. Do this several times. You should hear a click coming from the bypass valve's piston each time the throttle is opened or closed.
PostPosted: Sun Aug 24, 2003 12:02 pm    Post subject: Found my problem, was the turbo rebuilder! Reply with quote
Well guys, I had a few minutes this evening, so I finally did a few minutes worth of work on my motor (has been in an engine stand for months).
Guess what? The turbo that I bought from my Porsche dealer had the bypass valve installed BACKWARDS!!
No wonder I couldn't get more than 4 or 5 PSI of boost! Mine had to have boost in order to seal the bypass and is also the reason that it did not click when blipping the throttle.
Page 2 of 2
