john h
Posted: Tue Nov 22, 2005 11:11 am Post subject: |
Andrew,
When I bumped the horsepower up in my old non turbo beast in the late 80's the 924 clutch used to slip (even with anew clutch assembly) so I had Giltraps install a clutch assembly out of the 5 cylinder Audi Coupe - from memory it was a straight fit and didn't require any machining.
It had slightly higher clamping force so it stopped the slipping. _________________ Remember a Porsche is not just for Christmas,
Andrew NZ
Posted: Tue Nov 22, 2005 12:45 pm Post subject: |
| john h wrote: | Andrew,
It had slightly higher clamping force so it stopped the slipping. |
Thanks John, I'll look into that. _________________ Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz |
Posted: Thu Jul 23, 2009 11:11 pm Post subject: |
Andrew, John, did either of you make any progress on identifying the specific Audi 5-cyl parts? Not that it matters to me personally, as I'm not doing anything with an NA, just to satisfy my curiosity... _________________ erstwhile owner of just about every 924 variant ever made |
Rob_Hooper
Posted: Fri Jul 24, 2009 5:40 am Post subject: |
Hi Andrew,
I got my clutch for my 924 race car upgraded in Auckland, there was a clutch place near the overbridge close to the mcdolnalds HQ, i cant remember the name of the street you may know the place. The fingers were upgraded to a 1 ton clutch, never had any issues with slipping, i then just used a standard clutch plate. (that was about 8 years ago)
I also have a fidanze ALU flywheel that i am no longer going to use if you are thinking about changing your flywheel, _________________ Cheers Rob
924
931
968 CS |
Andrew NZ
Posted: Fri Jul 24, 2009 3:14 pm Post subject: |
| Rob_Hooper wrote: | Hi Andrew,
I also have a fidanze ALU flywheel that i am no longer going to use if you are thinking about changing your flywheel, |
Hi Rob, thanks I know the place you're talking about. My original post was in 2005, so it was sorted long ago and I have no use for the flywheel now as I have the rotary in it now. I do know someone that could be interested in it though so I'll send you an email.
Dan, I think it was an Audi 200 pressure plate I used in the end. _________________ Andrew
1977 RX924 race car
Posted: Thu Sep 10, 2009 10:15 pm Post subject: |
so a stock NA clutch disc with an audi 200 pressure plate is an effective, cheap , bolt on upgrade ? or am i missing something _________________ 1979 NA
my Porsches Arse!!! |
Andrew NZ
Posted: Fri Sep 11, 2009 11:36 am Post subject: |
| Scorpio wrote: | | so a stock NA clutch disc with an audi 200 pressure plate is an effective, cheap , bolt on upgrade ? or am i missing something |
Worked for me with your BAE setup. _________________ Andrew
1977 RX924 race car
Posted: Fri Sep 11, 2009 12:09 pm Post subject: |
| Andrew NZ wrote: | | Scorpio wrote: | | so a stock NA clutch disc with an audi 200 pressure plate is an effective, cheap , bolt on upgrade ? or am i missing something |
Worked for me with your BAE setup. |
and i now have the whole setup including the pressure plate and clutch
Cheers Andrew _________________ 1979 NA
