Sunroof seals
dpw928
PostPosted: Sun Feb 23, 2003 9:28 am    Post subject: Sunroof seals Reply with quote
Just installed new seals (upper and lower) on my 81 and now the sunroof sits up about 1/8" above nrmal. Will it settle as the seals conform or do I need to get a bigger hammer?
Thanks,
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
PostPosted: Sun Feb 23, 2003 3:29 pm    Post subject: Reply with quote
It will settle over time....
gohim
You're kidding about the hammer right?
You didn't get the seals on right, or the sunroof would have fit in very close to flush, and tight.
As you already know, the seals are retained on the flanges by a continous metal clip inside of the seal flange.
As you install the seals, don't strecth them there would be a little leftover, even if you didn't stretch them, but if you did stretch them, YOU CAN NOT CUT OFF THE EXTRA LENGTH. Otherwise, as the seal heat cycles it will shrink back down, and become TOO SHORT.
If you did the job right, there should only be about 1.5"-2.0" left. If there is more than that you stretched it, and if there is less than that, you probably didn't get the seals all the way onto the flanges.
dpw928
PostPosted: Sun Feb 23, 2003 3:42 pm    Post subject: Reply with quote
Just kidding about the hammer. I did get them on all the way. There was about 3/4" on the large one to cut off and none on the small seal. I was wondering if I should use a lubricant to help seat them.
BTW does anyone have any spare plastic mounts for the hidden wind visor? Mine disintigrated wen I removed the sunroof. Guess 6 years of hot and cold storage got the best of them.
Thanks,
Dennis
81 931 5 sp
78 928 5 sp Silver
gohim
PostPosted: Mon Feb 24, 2003 1:39 am    Post subject: Reply with quote
Buy new hinges for the wind deflector, they all crack with old age, and you can still buy new ones for less than $30 each.
1982Porsche924
PostPosted: Mon Feb 24, 2003 4:33 am    Post subject: Reply with quote
Ah, the joys of not having a sunroof.
1979 Porsche 924 "S"
Engine: Euro pistons, Light Flywheel, Weber TB, Bursch Header, Cam Wheel
Suspension: Front coil-overs, adj sways, Solid bush. Thicker tors. bars, 5-bolt, BBS rims
Body: Fiberglass widebody kit, 931 Nose
dpw928
PostPosted: Mon Feb 24, 2003 5:03 am    Post subject: Reply with quote
Hey, sunroofs are great! In my 16 years of 924 ownership, I must have opened the sunroof at least three or four times. And those leaking seals are great for keeping the carpets and seats clean.
Dennis
81 931 5 sp
78 928 5 sp Silver
PostPosted: Mon Feb 24, 2003 11:59 am    Post subject: Reply with quote
My sunroof is off more than its on from April until October!
1982Porsche924
PostPosted: Mon Feb 24, 2003 2:55 pm    Post subject: Reply with quote
are the no sunroof 924s rare? because it seems like just about everyone has one.
Porschephile
PostPosted: Mon Feb 24, 2003 4:16 pm    Post subject: Reply with quote
I think the no sunroof is rare.
also, I don't have a leaky seal on the sunroof, but I do on the hatch, by the rear left side. annoying when washing. but easy to take care of...drips on the seat only.
werd B.
81turbo
PostPosted: Tue Feb 25, 2003 1:30 am    Post subject: Reply with quote
The no sunroof cars are rare because the purchasers decided not to pay the cash for the extra option. I guess autos are rare to then, but who the hell wants it. Also the cars with sunroofs are more ridged due to the bracing for the sunroof.
jpab924
Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
PostPosted: Tue Feb 25, 2003 3:15 am    Post subject: Reply with quote
Both 78s I own have no sunroof, and the 77 I had also had no sunroof. They couldn`t be that rare....
PostPosted: Tue Feb 25, 2003 10:30 am    Post subject: Reply with quote
I used some short pieces of hose on the latches to give a tighter hold. [url=http://photos.msn.com/viewing/photo.aspx?GXjoJRPv*Lq8VA9E0sByrKOS3zy2BjeUuw5NU3ajFeewa2htw6CT2gxVN4qHRXtZkcArMco6fUoDNciWp5!yRJt1TUF!NWc5bXiedeDRa0B6mGQbgrw4gw$$]Photo: Sunroof Latch[/url]
dpw928
PostPosted: Tue Feb 25, 2003 12:33 pm    Post subject: Reply with quote
Smoothie,
Thanks for the hose tip. I'll try it when the weather warms up.
Dennis
81 931 5 sp
78 928 5 sp Silver
PostPosted: Wed Feb 26, 2003 2:12 am    Post subject: Reply with quote
hey smoothie why is your sunroof black but the rest of interior brown
3 928s,
