The linkage wiggles around!!! :-O
SwissRomeo924
PostPosted: Sun Sep 01, 2002 12:09 am    Post subject: Reply with quote
Hey,
The linkage(shifter) isn't spose to wiggle around while the car is in a gear right? I've heard of some "shell" that the linkage rods connects to that gets worn.? It's starting to make it difficult to shift into reverse, 1st, sometimes 4th, and it's pretty annoying. How do I fix it so it doesn't wiggle around anymore?
PostPosted: Sun Sep 01, 2002 3:26 am    Post subject: Reply with quote
You may need new bushings, the procedure is in the FAQs.
http://www.924.org/techsection/GarageFAQ.htm#snailshellshifter
[ This Message was edited by: Paul on 2002-09-01 03:33 ]
PostPosted: Sun Sep 01, 2002 3:27 am    Post subject: Reply with quote
First you have to find where it's loose. If you're as lucky as me, it will be right there at the shift lever under the boot. My linkage just fell off at that point a while ago. I held it together by hand for the trip home and fabricated a replacement for the clip in there from some heavy hanger wire.
Joes924
PostPosted: Sun Sep 01, 2002 3:34 am    Post subject: Reply with quote
Try changing the the tranny fluid also
youll need a hand pump that fits on the oil
jug to full it.Theres bushings on the tranny to that are hard to get to withut alot of WORK.
SwissRomeo924
PostPosted: Mon Sep 02, 2002 6:12 am    Post subject: Reply with quote
The tranny fluid has been changed and it didn't help it alot... I just switched shift linkages out and the plastic liners are good so I'm guessing that means I have to drop the rear end correct?
Joes924
PostPosted: Mon Sep 02, 2002 6:21 am    Post subject: Reply with quote
If your clutch is adjusted right and the linkage 2..live with it or pull it and replace You should of put in some redline tranny fluid I hear its really good stuff.
PostPosted: Mon Sep 02, 2002 10:53 pm    Post subject: Reply with quote
Yeah, you'll probably have to deal with the rear end. Do it. If you don't, there's a very good chance you'll end up destroying the trans. If you destroy that trans, they're virtually impossible to find the parts for, so you'll end up swapping in an Audi-style box. Much more effort than fixing the bushings, trust me, BTDT.
PostPosted: Tue Sep 03, 2002 2:13 am    Post subject: Reply with quote
Didn't someone here cut access holes in the body to get access to the linkages from above (from inside the car)?
PostPosted: Tue Sep 03, 2002 2:49 am    Post subject: Reply with quote
Me.
PostPosted: Tue Sep 03, 2002 4:15 am    Post subject: Reply with quote
A ha! Then it's safe to say you're not terribly opposed the practice. If it ever becomes necessary, that's probably the way I'll go in.
How'd it go in DesMoines, Vaughan? Get your car? Get anything else?
PostPosted: Tue Sep 03, 2002 4:39 am    Post subject: Reply with quote
The trip went well, if boring and slow... but that's the better way to make a tow. Exhausting, towing for 20 hrs. Got the car, it's running now, though it won't stay running (thinking bad control pressure regulator or wiring)... had a bad fuel pump, haven't even found the relay yet (but so what). It's very ugly, needs paint badly. Going back to the original, dark silver metallic of some sort.
AznDrgn
PostPosted: Tue Sep 03, 2002 11:59 am    Post subject: Reply with quote
Does that cause problems with the 4 speeds as well? I have a '78 with the audi 4 speed and it moves while in gear but I don't have any problems at all shifting. Where is the lnkage section that wears out in the back? All I saw when I had the tranny down to do the clutch was the linkage from the shifter going to a bar that stuck up out of the top the the tranny.
SwissRomeo924
PostPosted: Wed Sep 04, 2002 6:38 am    Post subject: Reply with quote
I think redline fluid was put in the rearend, it was pensoil. Anyways cutting through the back sounds like a good idea, screw dropping the transmission... that sounds painful. Where do you cut through and what parts do i need to fix it?
Thanks!
PostPosted: Wed Sep 04, 2002 7:37 am    Post subject: Reply with quote
hey actually you dont need to drop the tranny if you jackup the rear end so you can get under you should be able to get under and change the linkage, it will be difficult but not too bad, helps if you have slim hands and are mecanically inclined, this is only so if it is the linkage on the tranny end
AznDrgn
PostPosted: Wed Sep 04, 2002 11:37 am    Post subject: Reply with quote
Is that linkage only on the 5 speed or is it on the 4 speed too?
