Engine knock detection
Arvidw
PostPosted: Mon Dec 17, 2012 12:47 am    Post subject: Engine knock detection Reply with quote
Today I installed a VW knock sensor on my 924. It is connected via the microphone port on my laptop to some headphones. The sensor is bolted to the cast iron engine block on one of the mounting points of the steel coolant return pipe. (the one closest to the center of the engine)
I find it quite amazing what sound you can hear without the engine running, a squeaking clutch lever, the shifter mechanism in the transmission, the thottle valve opening and closing, injectors firing in test mode. It really does give a very nice and clear sound.
However with the engine running the only thing I can hear is valve train noise, from 1000-6000rpm I can only hear the clattering of tappets and valves.
Has anybody got any experience with audible knock detection on a porsche 924 2.0? If so, what did you use, what did hear, up to which engine RPM where you able to hear engine knock?
Porsche 924 2.0 Kompressor 136.1wHp @ 5650rpm / 201.9wNm @ 3900rpm (dyno @ dp-engineering.nl)
PostPosted: Tue Dec 18, 2012 5:07 am    Post subject: Reply with quote
Just bought myself a KS-4. The pro kit (which a mate has) allows you to listen in for knock whilst tuning. Once set the KS-4 will warn if knock starts http://www.phormula.co.uk/
Where did you bolt your sensor?
PostPosted: Tue Dec 18, 2012 5:36 am    Post subject: Reply with quote
I've purchased but not yet installed a Knocksense (http://www.viatrack.ca/) after reading several posts on the topic.
PostPosted: Tue Dec 18, 2012 7:17 am    Post subject: Reply with quote
OT:
Put a knock sensor on the Benz a couple years ago. Got it calibrated to the data AQ (not hooked up to control advance) and went out for a few laps. About 5 laps in, the engine threw a rod out of the block right where the knock sensor was mounted. Later the knock sensor data showed all normal until a massive spike and then flat lined.
Chuck
1981 924 Turbo sold
1982 924 Turbo sold
Arvidw
PostPosted: Tue Dec 18, 2012 7:24 am    Post subject: Reply with quote
The sensor has been placed here:
@Carrera RSR, Have you already spend time tuning your 924 with the KS-4 Analyser? If so, how did you do that? Advance ignition and do a 2000-7000rpm run and listen for detonation, if not, advance even more?
@Ideola, Are you going to use the knocksense in combination with a EFI controller (Megasquirt?) or are you going to use the LED indication for tuning your engine?
PostPosted: Tue Dec 18, 2012 8:06 am    Post subject: Reply with quote
My engine is still being built so no experience of tuning yet.
I was interested in the position of the sensor as that lug is an option but my fear its too low. The sensor needs to be as close to point of combustion as possible.
PostPosted: Tue Dec 18, 2012 8:43 am    Post subject: Reply with quote
Fifty50Plus wrote:
OT:
Chuck
Sounds like the failure wasn't knock-related, but was just due to a failure of the rod (bolt/nut/cap, etc) So, yeah knock-detection won't save you from everything as stuff can still go "FUBAR" unexpectedly.
I agree that the knock sensor should be closer to the combustion chamber. Many manufacturers mount them on the intake manifold for this reason (my turbo car for one).
PostPosted: Tue Dec 18, 2012 9:32 am    Post subject: Reply with quote
Fiat - agreed. Just thought it was ironic that we were able to capture an unrelated failure the moment we put on more data acquisition.
WE were going to eventually make some electronic timing advance changes to see if we could induce knock and detect it. Wound up totalling the car before we went forward with further knock sensor testing. We will attempt to transfer the tech stuff to the 924 as we build it.
Chuck
1981 924 Turbo sold
1982 924 Turbo sold
WEASEL149
PostPosted: Thu Dec 20, 2012 2:49 am    Post subject: Reply with quote
A few others (Cedric?) have used the other lug between 3 and 4 which you can see near the crankcase breather in that photo. That's where mine is going.
When tuning, it's advisable to use electronic filtered detection and also listen on headphones/detcans. The human ear is a much more accurate 'device' provided you know what knock/detonation sounds like.
1979 UK 932
PostPosted: Thu Dec 20, 2012 3:41 pm    Post subject: Reply with quote
I use that boss, correct, looks kind of good compared to the recommended location in the bosch automotive handbook. Together with a turboxs knocklite, which does some kind of simple noise calibration curve. Works really well could sense knock long before you could here anything. Since I change a faulty ignition module and wur (ran lean according to wb) ive never had any problems since. Best engine investment yet:-)
PostPosted: Thu Dec 20, 2012 10:24 pm    Post subject: Reply with quote
Have you fitted the sensor using the engine mounting bolt?!
Would the boss under the manifold just above the oil filter housing be better located? Its nearer the top of the pistons at TDC. Would it be too harsh an environment for heat for the sensor and cabling, bearing in mind my temps should be circa 30% less with the ceramic coatings I've used on the latest build
Arvidw
PostPosted: Fri Dec 21, 2012 5:08 am    Post subject: Reply with quote
@Weasel and Cedric, I'll try that point the next time. I have to fabricate some M10 to M8 bolt as my sensor only accepts M8. As it is probably a much better position it is worth the time and effort.
@Carrera RSR, that would indeed be a very nice spot to place the sensor. It is too bad it is so difficult to reach
I recorded the sound of my engine today. I tried to introduce engine knock by advancing the ignition drastically in only one load bin in my IGN table.
Video: http://youtu.be/rdEVSZz0n8E
I could really feel the engine struggling around 3300rpm however I can't really hear detonation around 3300rpm in the sound clip. However in the beginning of the clip just 2 seconds after opening the throttle I do hear some strange rattling noises so I'm wondering wetter that is detonation?
PostPosted: Fri Dec 21, 2012 8:37 am    Post subject: Reply with quote
You may find some useful info in this old thread Arvid:
http://www.924board.org/viewtopic.php?t=22379
Allan @ DTA wrote:
ksis
PostPosted: Fri Dec 21, 2012 9:13 am    Post subject: Reply with quote
I thought a knock sensor should be placed on number one piston at the middle of the stroke. Check the placement of a sensor on a MK2 VW 1.8.
64 Spitfire
76 TR6
04 Jetta
77 Schwinn Scrambler
Awsome pair of Chucks
http://www.cardomain.com/id/ksiskin
PostPosted: Fri Dec 21, 2012 9:41 pm    Post subject: Reply with quote
Well that was 4 pages of hot air and 20 minutes of my life I will never get back! As usual no conclusion. Just multiple opinions.
