Fuchs wheels
Cbass
PostPosted: Wed Jul 17, 2002 11:22 am    Post subject: Reply with quote
Does anyone know where to find good Fuchs that would fit a 924? I know they made them in 16x8, but did they make any 16x7-8" wheels that would fit a 924(with 5 bolts)
PostPosted: Wed Jul 17, 2002 12:17 pm    Post subject: Reply with quote
I have a set of Fuchs 6x16, so I'm sure they made 7x16's too. Don't know where you might find them. I got mine about 6 years ago from a place in or near Chicago - had a German sounding name - Stuttgart something... I have pics of mine on my website.
The backspacing was different between stock and the Fuchs that I put on - this is mentioned on the website. With the stock '82 931 suspension, the tires rubbed in front. I installed stiffer springs and a thicker stabilizer bar - that eliminated the rubs.
[ This Message was edited by: Smoothie on 2002-07-17 12:34 ]
Cbass
PostPosted: Wed Jul 17, 2002 2:06 pm    Post subject: Reply with quote
Okay, I am hoping to get 16X8s. I have seen them in the auto atlanta catalogue, in 16x6-9"... I want 7s on the front and 8s on the back... Yes, I am aware of what they cost, I just want to know if there are any 7s or 8s with the correct offset...
Joes924
PostPosted: Wed Jul 17, 2002 3:21 pm    Post subject: Reply with quote
You been here seen this yet its kind of cool im still a little stoked on the thought.
https://www.discounttiredirect.com/secureindex.html
John H
PostPosted: Wed Jul 17, 2002 4:07 pm    Post subject: Reply with quote
Try these guys
http://www.partsheaven.com/used_parts.html
For racks of wheels look at this
http://www.partsheaven.com/parts/rack_wheels_all.jpg
Or your coudl try Wheel enhancements
http://www.wheelenhancement.com/Style.htm
These last guys have a large selection and I gather they also refurbish old Porsche rims.
which ever way you go be prepared to pay high dollars for the rims and for tyres.
16 inch tires will become a bit of an oddball size as most performance tires are now either 15, 17 or 18 inch diameter
dwak
PostPosted: Wed Jul 17, 2002 9:00 pm    Post subject: Reply with quote
Cbass,
I just bought a set that I'm using on my 931 that were on an older 911 and fit perfectly.
They're 7x15's. They're on Ebay all the time. I think 'cookie cutters' are a better deal.
dwak
Cbass
PostPosted: Thu Jul 18, 2002 3:29 pm    Post subject: Reply with quote
Do you know which 911 they came off of? The 930 had 16x8s on the back, and probably 16x7s on the front.
[edit] Found these on Ebay... They are off a 911, I'm not sure which, but they a 16x7 and 16x8, about $700 with tires. I'm not sure what the offset is, but the wheels look much deeper than yours Dwak.
Part # is 911361020
_http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=1844386509________________
2001 Black all leather Enzo Carsinis
[ This Message was edited by: Cbass on 2002-07-18 15:52 ]
[ This Message was edited by: Cbass on 2002-07-18 15:55 ]
Joes924
PostPosted: Sat Aug 03, 2002 2:48 pm    Post subject: Reply with quote
yea those will work.nice real nice
Cbass
PostPosted: Sat Aug 03, 2002 4:09 pm    Post subject: Reply with quote
You think they would fit? I did a little digging, and found out they did make a run of late offset Fuchs, for the 911 speedster! Right up until '89...
Joes924
PostPosted: Mon Aug 05, 2002 1:48 am    Post subject: Reply with quote
I dont know about that I have no need to research it either cause I dont have a set
there really nice.
Cbass
PostPosted: Tue Aug 06, 2002 6:54 pm    Post subject: Reply with quote
No good, the speedster wheels were early offset... I do know they made early 911 wheels in 16" though, so it's just a matter of tracking them down...
Hey Dwak, could you find the part# for you wheels?
eturbo924
PostPosted: Wed Aug 07, 2002 4:30 am    Post subject: Reply with quote
So the 944 Fuch alloys 15 inch will not fit 924? 911s will? Why do the cookie cutters fit and not the Fuch alloys? Would they have changed the offset that much?
Eric
924 turbo
PostPosted: Wed Aug 07, 2002 6:56 am    Post subject: Reply with quote
Cookie cutters do not fit. They stick out. If your suspension is hard enough, they won't rub. The only thing you need to know to make the rims fit is offset (and of course width). 924 5-bolt rims should all be around 52.3mm. Anything that is much lower (like 23.3mm) won't fit unless it is very narrow. Anything that is higher (like 65mm) will require spacers.
John H
PostPosted: Wed Aug 07, 2002 4:25 pm    Post subject: Reply with quote
Cbass,
The specs fro those wheels are
Offset 23.2mm for the 7 inch and 10.6 mm for the 8 inch
The wheels were fitted to 86 onward 944’s, 1978 onwards 911’s, and the 7 inch were winter rims for the 930.
On the 7 inch the distance from the mounting face to the inside face is 112 mm. From the mounting face to and from the road side face is 66 mm.
On the 8 inch the distance from the mounting face to the inside face is 112 mm. From the mounting face to and from the road side face is 91 mm.
For the normal 924 wheel (part number 477 601 031 14x 6 eight spoke rim) the dimensions are:
the distance from the mounting face to the inside face is 96.4 mm. From the mounting face to and from the road side face is 56 mm.
So the rims should and have clearance to the inner fender but marginal to the outside fender.
I ran the 6 inch by 16 fuch wheels on my 924 turbo for a while. Note 6, 7 and 8 inch x 16 all have the same first 9 numbers in the part number the last 2 number of the 11 digit number tells you what the wheel is
97 =6 inch unvarnished, 43 = 6 inch black star and polished rim, 98 = 7 inch unvarnished, 44 = 7inch black star polished rim, 99 = 8 inch, 45 = black star polished rim.
The 6 x 16 with 215/55 x 16 fitted nicely and looked really good. However under racing conditions ( or really hard driving I ended up cooking the paint on the front fenders tire rubbed under extreme cornerign and on a tight track this eventual resulted in slight bubbling of the paint.
Never tried the 7 inch rims and when I went the GT route I had plenty of clearance
[ This Message was edited by: John H on 2002-08-07 16:30 ]
Cbass
PostPosted: Wed Aug 07, 2002 6:18 pm    Post subject: Reply with quote
I've always been under the impression that a 215 would be best suited to an 8" wheel. It worked really well?
I would like a 16", because it's getting hard to find a good 15" performance tire...
