Two more gauges - ideas?
PostPosted: Mon Oct 18, 2010 7:49 pm    Post subject: Two more gauges - ideas? Reply with quote
I currently have for my NA to turbo project
Boost gauge
Water temp gauge
Oil Temp gauge
Oil Pressure gauge
And have room for two more, im thinking perhaps two of the following
EGT gauge
A/F gauge (currently have a digital version connected to JAW) and megasquirt
Fuel pressure gauge(electrical cabin mounted)
The dyno tuner place wanted me to drill 4 holes to mount 4 EGt gauges for them to tune with in my BAE manifold, but said they may be able to get away with one, any recommendations on this and the gauges?
1979 NA
my Porsches Arse!!!
Rich H
PostPosted: Mon Oct 18, 2010 8:26 pm    Post subject: Reply with quote
If it's tuned properly then they are just distractions....
PostPosted: Mon Oct 18, 2010 10:17 pm    Post subject: Reply with quote
G force meter and fluxcapacitor
PostPosted: Mon Oct 18, 2010 10:52 pm    Post subject: Reply with quote
good point . For piece of mind they continually update me on the status of the engine . Drop or rise in fuel pressure may indicate pressure regulator about to fail or fuel pump failing resulting in lean or rich condition. Egt would help tuning . Good point though maybe I'll use the space fir my sweet alfa Romeo cup holder best holder ever!
1979 NA
my Porsches Arse!!!
PostPosted: Tue Oct 19, 2010 12:35 am    Post subject: Reply with quote
Yep, I agree with Rich.
I`ll look at my oil temp or pressure when cruising or just after very heavy driving. Honestly have never really seen my boost gauge while under boost. It`s just for the passenger`s amusement as I`m hanging onto the wheel and watching where the F I`m going, very quickly.
Then can see the boost later when I replay the data log. BTW, with the JAW, slowest display rate is 8Hz, and will only be readable on a steady throttle anyway. Running a TE WBo2 now with no display, it`s simply not needed. I occasionally use a LED DVM display (velcro`d to dash) on the 2nd programmable output, set for 1-2 V out corresponding to 10-20 AFR, for initial tuning on a new fuel, E10 or Boost 98. E85 and full flex fuel capability coming soon.
Allan @ DTA wrote:
PostPosted: Tue Oct 19, 2010 12:38 am    Post subject: Reply with quote
Seriously, a G tech on the dash is a useful tuning tool and also fun to watch.
Gotta get a later unit so can store and also datalog.
PostPosted: Tue Oct 19, 2010 3:21 am    Post subject: Reply with quote
Voltmeter.
PostPosted: Tue Oct 19, 2010 3:27 am    Post subject: Reply with quote
If you have room for two more gauges, I'd see if you could combine those spaces and install a MegaView display or something along those lines so you can monitor MegaSquirt without a laptop.
JayZzzz4
PostPosted: Tue Oct 19, 2010 3:38 am    Post subject: Reply with quote
fuel-air mixture gauges are pretty cool, I want one for my car, but their a little pricey
White 1987 Porsche 924S manual
PostPosted: Tue Oct 19, 2010 7:51 am    Post subject: Reply with quote
my iPhone 4 app does this I have a digital speed app which is very spot on as fir the g force app I think I still need to play around with it for a bit
1979 NA
my Porsches Arse!!!
PostPosted: Tue Oct 19, 2010 7:55 am    Post subject: Reply with quote
I was looking at a carputer for my d ouble din dash but as it stands they're too slow too expensive and take longer then I like to bit up , their was an option of running a certain two din gps/ DVD etc player with wifi and direct acces to windows ce but from what I've read megaton won't run on windows ce
1979 NA
my Porsches Arse!!!
PostPosted: Tue Oct 19, 2010 7:58 am    Post subject: Reply with quote
My flux capacitor is broken the aliens stole it and decided to use it with some 5 w oil for an an$l probe on snobby 911 drivers
1979 NA
my Porsches Arse!!!
PostPosted: Tue Oct 19, 2010 9:09 am    Post subject: Reply with quote
Uh, no. I was thinking of something like this:
http://www.diyautotune.com/catalog/lcdash-digital-touchscreen-dash-display-for-megasquirt-p-167.html
Also, IMHO, what you need is not tuning, but monitoring. Tuning you can do after the drive is finished or with a passenger.
MegaTunix is a decent solution since I think Linux should make for a better carputer operating system.
Otherwise there are Palm emulators for Windows CE that will allow you to use the Palm-based MegaSquirt monitoring and tuning software.
PostPosted: Tue Oct 19, 2010 9:16 am    Post subject: Reply with quote
IMO, you do not need to drill 4 EGT taps on the manifold. For the power level and tuning that will be done it's just not needed. If you were trying to squeeze every last HP out of the car and were running it razor thin on timing and fuel, then yes.
You should get a LC-1 or AEM UEGO wideband air/fuel ratio gauge and 1 EGT port.
