Gearbox mod. high speed cruising / higher topspeed 5th gear
PostPosted: Tue Jun 29, 2010 5:47 pm    Post subject: Gearbox mod. high speed cruising / higher topspeed 5th gear Reply with quote
It is known that the "Audi" gearboxes in our 924s are almost identical to today's Audi A4 and perhaps also A6 models.
i've personaly seen an 2002 Audi A4 gearbox and it would fit a 924 NA(small diameter input shaft)
now...there are high end A4s and A6s that do high cruising speeds like 140Km/h @ 2800 RPM.
These are mainly diesel powered cars but i think the gearboxes are the same...maybe just a bit more beefed up compared to the ones on regular gas cars.
The problem i'm trying to solve now is that if i want to do 140 on the highway i'm forced to run at 4000+ RPM. That ruins mileage and makes for a noisy ride in the 924.
My ideea is to take the 5th gear pinion and syncro from the A4/A6 gearbox and put it into the 931 audi gearbox.
The result would be a fast 931...but with a high speed cruising capability and i'm quite sure higher top speed.
Does anybody have the possibility to check/try/investigate this ?
PostPosted: Thu Jul 01, 2010 2:19 am    Post subject: Reply with quote
Interesting idea Morghen, can understand your reasoning. Can`t offer any help though, know bugger all about interchangeability on the manual boxes and nothing whatsoever about A4 or A6 boxes. Wouldn`t mind seeing a pic of one if you can post it.
Is the 944 or 951 tranny that has the tall 5th gear, that racers especially don` want. Might be worthwhile going through the ratio charts. Also what is your (Euro) final drive ratio? Is there lower ratio ring/pinion sets that may change over from other trannys. Sure it will affect all gears a little but be most noticeable in top. Will give a broader spread between all gears that may or may not be an improvement, particularly between 1 & 2.
PostPosted: Thu Jul 01, 2010 5:01 am    Post subject: Reply with quote
i will try to get some pics of the A4 and 924 gearbox side by side.
i have no ideea about the final drive ratio...however i'm not happy with the current 944NA gearbox...this gearbox sucks big time.
For city driving you have to revup to 3000-3500 just to keep up with diesel trafic. i dont like noisy revvy driving in the city....i want taller gears for the city driving and not only.
Also...for cruising and driving outside the city...yea its fast like a rocket but top speed is only about 220-230 and the much wanted 140 is only after 4000RPM....that is too noisy for long journeys.
9XX Girl!
PostPosted: Thu Jul 01, 2010 5:23 am    Post subject: Reply with quote
Ideola had a gearing calculator spread sheet on his website but i can't seem to get it to download http://garage.ideola.com/downloads.html
mine will do 90mph (145km/h) in 5th @ 3500 and still pull more. This is with an increased rear wheel diameter of 662mm instead of the stock 614mm.
Ok bigger rear wheels make all the gears taller but i would like to think there would be enough toque in a 924 N/A to make it work morghen let alone a 931. In theory, with my tyre sizes it should reach 148mph (237km/h) at red line,,,,, but as being caught speeding over 100mph in the UK results in a ban from driving, i cannot afford to test it.
924 (84) N/A 2 ltr - 5 Speed - BLACK - Project (looking for 200BHP, any ideas!)
BOTH ON THE ROAD, BOTH USED EVERY-OTHER DAY
PostPosted: Thu Jul 01, 2010 5:46 am    Post subject: Reply with quote
145 at 3500 ? what gearbox is that....snailshell or ?
the diameter on my wheels is 627mm
9XX Girl!
PostPosted: Thu Jul 01, 2010 6:14 am    Post subject: Reply with quote
13mm bigger than stock.
maybe rubbber 35mm bigger again (48mm total) makes the difference?
my gearbox is stock for a late 1984 942 N/A... i think
zimm
PostPosted: Thu Jul 01, 2010 6:40 am    Post subject: Reply with quote
90ish mph @ ~4000rpm on stock tyres sounds about right for both my NA's, my 944, and my 932
what transaxle is in yours morghen ?
click below for spreadsheet
http://garage.ideola.com/downloads/PorscheTrans1.xls
6 bikes, 9 cars, 1 van.... the more you have the less they work.
9XX Girl!
PostPosted: Thu Jul 01, 2010 6:48 am    Post subject: Reply with quote
Thanks for the direct link zimm. It wont load on Firefox for me.... I've PMed Dan as i thought the link was bust but if you can get it up it must be ok.... i will try it on Microsoft Internet Explorer
PostPosted: Thu Jul 01, 2010 6:54 am    Post subject: Reply with quote
i use an early 944 NA gearbox....but its too short for the 931.
9XX Girl!
PostPosted: Thu Jul 01, 2010 7:11 am    Post subject: Reply with quote
Ok i can get it on Internet Explorer and Safari but not Firefox
So... if i type my tyre size into cells B5 C5 D5 on Dans spread sheet. (255/50/16), 3500 rpm gives me 90.94mph (145.504km/h). Cell F52
5500 rpm is 168.88 mph ouch... i want to go there....
So how do i workout what gearbox i have?????
PostPosted: Thu Jul 01, 2010 8:03 am    Post subject: Reply with quote
Paula, most likely your problem is related to the cache in your Firefox browser. If you had an aborted download attempt from a previous session, the incomplete file will be in your cache. You can force your browser to fetch a new copy by shift-clicking the reload button. There's nothing magical or special going on on that download page that would prevent Firefox or any other browser from getting to the file, so it has to be a local browser issue.
And for the record, I can't take credit for the spreadsheet. Applebit put it together.
9XX Girl!
PostPosted: Thu Jul 01, 2010 8:11 am    Post subject: Reply with quote
Thanks Dan & triple thanks Applebit all that work in Excel given away for free
PostPosted: Sat Jul 10, 2010 8:36 pm    Post subject: Reply with quote
So...a guy who opened both the A4 box and the 924 box said they are different inside and you could not use the 5th gear from one to another.
but...he swears that the 6 speed A4 1.8Turbo gearbox fits the 924/944
He said he can get me one of those 6 speed gearboxes to look at and if i want it i can buy one.
that would be great...6 speed on a 924
1900 RPM at 62mph and @100mph at 3000RPM
rat
PostPosted: Sun Jul 11, 2010 8:28 pm    Post subject: Reply with quote
I'd love a 6 speed with that taller top in all my cars. I'm an old man at heart despite my real age.. Just need a tweed cap.
Just the case of time and money..
PostPosted: Sun Jul 11, 2010 8:32 pm    Post subject: Reply with quote
well i've looked for a 6 speed before...from a 968..but the best price i could get was 1700 euro + shipping.
I think a 6 speed from an A4 would be much cheaper and easy to find.
