stpangia
Posted: Sat Feb 27, 2010 7:17 am Post subject: Re: Seeking Wheel and Tire Advice |
| stpangia wrote: | | also, i read somewhere that the 924 suspension can be fragile. |
If you hit something sliding sideways at a high rate of speed, or something hits you.
We ahve a name for people who say early steel suspension is flimsy. . .but I won't repeat it here.
Here's come inspiration, my Chump Car:
Posted: Sat Feb 27, 2010 8:25 am Post subject: |
LOL, Rasta, you're showing the wrong side....
oh and no, the suspension isn't weak. The later cast aluminum arms do tend to crack at times. _________________ Stefan
Posted: Sat Feb 27, 2010 8:32 am Post subject: |
Rasta, I love the checklist  _________________ erstwhile owner of just about every 924 variant ever made |
stpangia
Posted: Sun Feb 28, 2010 6:48 am Post subject: |
Thanks guys.
Any thoughts on on the wheels/ tires question? |
Posted: Sun Feb 28, 2010 9:20 am Post subject: |
Rasta I can't believe you made your better half wear double zeros!!!
Stpangia, the 14" setup should work and save you a few bucks. What do the rules have to say about tires?
I'd be more worried about the brakes, those non vented front rotors and rear drums are not going to like a 24 hour race. _________________ White 87 924S "Ghost"
Rocco R16V
Posted: Sun Feb 28, 2010 1:03 pm Post subject: |
A bigger wheel is going to weigh more, that will hurt performance.
if there was a bigger difference in width or sidewall height that would help cornering speed to offset the weight difference then it might be worth while. but on the 924 you dont need wider for accel performance and there wont be enough cornering performance difference to make it worth it. imo
if you could find some light 15" wheels there are a lot more tire options.
on our lemons VW we used 205/50/15 Falken Azenis RT-615 these had very good grip and are resonably priced link
also there is a big differnce in overall size between 195/45/14 (~21") and 225/45/16 (~24") tire size calc link
the falken in 195/60/14 is only $90, that would be closer to stock size than the 195/45/14s _________________ "Government exists to protect us from each other. Where government has gone beyond its limits is in deciding to protect us from ourselves. "
Ronald Reagan |
924guy
Posted: Sun Feb 28, 2010 10:23 pm Post subject: |
for lemons i would retain the stock set up, and run cooling ducts. heres why:
1. as said above the 14" wheels are lighter,
2. the stock brakes are more than adequate, but you DO want to keep the fronts cool with $5 worth of duct to limit heat fade.
3. swapping over to five lugs isnt too bad, but 4 lugs parts are so easy and cheap. ive got over 100 pounds of spare 4 lug parts + five wheels just sitting in my garage, and so do allot of others here whove done the upgrade already. there is little to no market for those parts, so stocking a complete set of replacements including wheels should be cheap and easy.
4. lots of hondas running local circuits that use 14" tires, finding cheap track tires should also be fairly easy.
edit, my brain read the post as a upgrade to five lugs at first, but ill leave the above anyhow. _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
Vince Ponz
Posted: Mon Mar 01, 2010 2:02 am Post subject: |
Leave the brakes stock. Check for wear on the front and back and tighten up the rears. With these cars being momentum cars stay off the brakes and try being smooth.
At Bridgehamton which closed I would get to 118 on the straight to a deep deep downhill and I never had brake problems. Just stay off them. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
Posted: Mon Mar 01, 2010 2:37 am Post subject: |
Yeah that's the ticket, don't use the brakes so they won't overheat.
I guess it depends on the track, but I've managed to melt the plastic hub covers and lug bolt covers on a 77 924 on the street. _________________ White 87 924S "Ghost"
Posted: Mon Mar 01, 2010 3:15 am Post subject: |
| Paul wrote: | Yeah that's the ticket, don't use the brakes so they won't overheat.
I guess it depends on the track, but I've managed to melt the plastic hub covers and lug bolt covers on a 77 924 on the street. |
You must be driving too fast on all those twisty roads by your house to do that kind of damage!
I would stick with refreshed stock 4 bolts and lightest rims possible. _________________ [This Space For Rent] |
Posted: Mon Mar 01, 2010 3:27 am Post subject: |
| flosho wrote: | | Paul wrote: | Yeah that's the ticket, don't use the brakes so they won't overheat.
I would stick with refreshed stock 4 bolts and lightest rims possible. |
Actually it was in 1977 coming home (State College, PA) from Whipple Dam State Park on route 26 (long twisty down hills). I approached one of the turns at 120 +. By the time I got to the bottom I had almost no brakes and the wheels were smoking. The hub and lug covers had to be replaced. _________________ White 87 924S "Ghost"
Posted: Mon Mar 01, 2010 9:18 am Post subject: |
Gee, I barely remember going to high school back then! But I guess smoking your brakes like that is memorable! _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Posted: Mon Mar 01, 2010 11:03 am Post subject: |
By 77 I had been out of high school for 8 years..... _________________ White 87 924S "Ghost"
924guy
Posted: Mon Mar 01, 2010 12:07 pm Post subject: |
| Quote: | | But I guess smoking your brakes like that is memorable! |
He didnt Inhale....  _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
