dash16
Posted: Sat Jun 27, 2009 4:19 pm Post subject: Stuttgart Shifting Block |
http://www.rsbarn.com/images/ShiftingBlock_800.jpg
Anyone ever seen/tried these? _________________ 1987 Porsche 924S Black/Black. 5-spd.
Options: AFX C79 261 398 423 650 651 657
1987 Mercedes 190E 2.3-16 Cosworth Pearl Black/Black. 5-spd.
STUTTGART PREVAILS |
Min
Posted: Sun Jun 28, 2009 2:46 am Post subject: |
that's a ridiculous amount of money for a block of metal with two holes drilled in it.
POORscheMAN
Posted: Sun Jun 28, 2009 4:07 am Post subject: |
I have one installed in my 968. Its absolutely fantastic!
Its not a short shift kit, so don't be misled. What it does do is tighten up the shift pattern, and takes all the slop out of it.
It took abut 3000 miles before mine was broken in, but now my car has crisp shifting with a nice positive feedback. Feels better then any new car Ive driven.
As for the price, it didn't seem so bad on the 968, but relative to the value of a 924 it would be quite an expensive mod for what it does. I think I would buy new OEM bushings before the shift block _________________ 1978 924
Audi 5K Throttle Body - 10:1 comp
Stage 1 Cam -MSD coil- Crane XR700 ignition - Headers
260# springs -26mm rear TBars-
poly bushings -Weltmeister sway bars
1980 924 N/A -- stock
1982 931
1988 944
1994 968 M030 |
Min
Posted: Sun Jun 28, 2009 5:19 am Post subject: |
like I said, block of metal, two holes, would take you 10 minutes to make on a drill press.
Posted: Mon Jun 29, 2009 1:08 am Post subject: |
i've made this part for myself out of POM. POM is PolyOxyMetilen...some sort of plastic. _________________ Supercharger and EFI kits
https://www.the924.com |
Min
Posted: Mon Jun 29, 2009 4:04 am Post subject: |
The one I just took off my car is made of plastic. Are they normally rubber or something?
Posted: Mon Jun 29, 2009 6:24 am Post subject: |
no they are all made of plastic. _________________ Supercharger and EFI kits
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Mon Jun 29, 2009 7:24 am Post subject: |
hi Morghen, is it a worthwhile mod? can you share a tech drawing of it so i can get one made?
cheers _________________ '86 944 |
Posted: Mon Jun 29, 2009 8:18 am Post subject: |
i'll try to get it tomorrow for you...but its basicaly a cube with two holes and some tolerances.
it took out some of the slop in my linkage..but there is still some...might be that i forgot the tighten something properly down there....i'll check tomorrow. _________________ Supercharger and EFI kits
J1NX3D
Posted: Sun Jul 19, 2009 11:15 am Post subject: |
| morghen wrote: | i'll try to get it tomorrow for you...but its basicaly a cube with two holes and some tolerances.
it took out some of the slop in my linkage..but there is still some...might be that i forgot the tighten something properly down there....i'll check tomorrow. |
Hi morghen, did you have any luck with your shifter? drawings? _________________ '86 944 |
Posted: Sun Jul 19, 2009 11:27 am Post subject: |
| Min wrote: | | would take you 10 minutes to make on a drill press. |
I am thinking of a thread. . .started by Min. . .ahhhmmmmmmmmmmmmm. . .ahhhmmmmmmmmmmmmmm _________________ Toofah King Bad
Rich H
Posted: Sun Jul 19, 2009 5:35 pm Post subject: |
I've made a few, they tighten up the shift nicely. I was planning on making a batch but I don't have a bandsaw and the plastic (I used oilon) is a bitch to cut by hand. _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Sun Jul 19, 2009 10:43 pm Post subject: |
I need to get some delrin and make a few, my cars could use them... _________________ Vaughan Scott
Posted: Mon Jul 20, 2009 12:21 am Post subject: |
i dont have the drawing here...i made it at work...basicaly its two positioned holes in a paralelipiped with some chamfer and some tolerances...i'll try to get it next week...if not i'll make another one for you guys. _________________ Supercharger and EFI kits
Min
Posted: Mon Jul 20, 2009 3:35 pm Post subject: |
| Rasta Monsta wrote: | | I am thinking of a thread. . .started by Min. . .ahhhmmmmmmmmmmmmm. . .ahhhmmmmmmmmmmmmmm |
If people want these I could make them. I really don't see how it improves things though, being that the previous one is made from hard plastic and not likely to wear that much. At least the one I took off my car wasn't worn at all, all the slop in my shifter was due to loose bolts and a worn shifter pin.
