For your viewing pleasure: Turbo Manifold
Jonus
PostPosted: Sat May 10, 2008 3:10 pm    Post subject: For your viewing pleasure: Turbo Manifold Reply with quote
Well...here it is after the car got her fill of our blood, sweat and tears. (Min and I)
I cant quite bolt it in at the moment as I am waiting on some SS spring washers, but you will get more photos when I have it all nestled in place for good - well, as "for good" as it can be right?
PostPosted: Sat May 10, 2008 3:33 pm    Post subject: Reply with quote
Wow, that is a hefty collector. How did you decide on the diameter?
Min
PostPosted: Sat May 10, 2008 4:20 pm    Post subject: Reply with quote
I like to call this 'copying' there is a few pictures of manifolds in maximum boost that are similarly sized.
Min
PostPosted: Sat May 10, 2008 5:17 pm    Post subject: Reply with quote
nice work, better to use copper washers though to go with copper exhaust nuts...
you can get them from Wurth in packs of 25 enought to doa the whole exhaust system...
Stuart
PostPosted: Sat May 10, 2008 9:39 pm    Post subject: Reply with quote
Wow! That's some serious welding! Stainless I assume?
Excellent work guys!
Min
PostPosted: Sun May 11, 2008 4:18 am    Post subject: Reply with quote
Stuart
Maximum boost recommends against copper, we're using stainless steel hardware.
Min
Min
PostPosted: Sun May 11, 2008 4:21 am    Post subject: Reply with quote
I did it all myself with a oxy torch, it pressure tests fine to 50psi, that was a learning experience alright(considering last time I torch welded was umm, 15 years ago?). Its not stainless, its mild steel. Its ceramic coated though. We also did that ourselves. Some of the welds don't look that great, but it will work fine.
Min
vemser
PostPosted: Sun May 11, 2008 4:50 am    Post subject: Reply with quote
http://rus.vems.hu/punbb/attachment.php?item=102
It's my BAE manifold. Just picture for viewing...
Pieter
PostPosted: Sun May 11, 2008 5:24 am    Post subject: Reply with quote
Did the ceramic coating yourself? How would one go about doing that. Looks like this manifold is going onto a NA head? What thickness is the steel you used? I might make copy of your mani, but with a mig welder instead, should be easier/ faster (at least for me). Well, maybe i will TIG it first, but inclusions will mean it wont be a perfect seal, so mig for seal.
Min
PostPosted: Sun May 11, 2008 6:44 am    Post subject: Reply with quote
Yep, http://www.caswellplating.com/powder/ceramics.html is the product we used, followed the instructions and it went on no problem.
Yep, 1/2 inch plate for the flanges, schedule 40 weld elbows for the piping (1/8 inch thick) http://sdsefi.com/techheader.htm
I just used the oxy torch because it was inexpensive and playing with hot flames is fun. Took a bit to get the hang of making it so it would seal though. If you do end up with pinholes, you can drill them out and weld over them pretty easily.
Min
Chrenan
PostPosted: Sun May 11, 2008 6:50 am    Post subject: Reply with quote
Nice work Min!
Min
PostPosted: Sun May 11, 2008 7:11 am    Post subject: Reply with quote
Chrenan wrote:
Nice work Min!
It turned out ok, next time we're going to spend alot more time making sure pieces fit better so we can get away with smaller welds on the runners, but it will work just fine.
Min
Min
PostPosted: Sun May 11, 2008 7:32 am    Post subject: Reply with quote
oh, forgot the mention, the flanges were plasma cut using a cad drawing that khal made up for me. If anyone wants it, I can send it along.
Min
Min
PostPosted: Sun May 11, 2008 8:55 am    Post subject: Reply with quote
Page 127 of maximum boost states
The most reasonable solution to fastener problems is stainless steel. Stainless steel bolts work better at temperatures above 1200F. Below that, stainless is nice but not cost-effective. Depending on the style of joint, three fasteners are possible: through-bolt, stud, or bolt. Observe the following guidelines:
- A through-bolt with nut (a con-rod bolt, for example) is always the first choice.
- A stud anchored in a threaded receiver (cylinder head to exhaust manifold, for example) is a decent second choice.
- Last and clearly least is a bolt screwed into a threaded reciever. These joints cannot stay tight unless secured with safety wire. Use only as a last resort.
Large, heavy, flat washers are necessary, as are lockwashers. Forget using any form of spring lockwasher, as the heat treat merely gets cooked out. Interference-style lockwashers, with ramps, ridges, or serrations, are the only lockwashers that are survivors.
Stainless steel mechanical locknuts are able to keep a positive lock at high temperature. Copper-alloy locknuts cannot cut the temperature; they simply sag.
Copper locknuts are good for NA applications (and is what I use on my NA car) but according to corky bell, they aren't adequate for turbocharged applications. As such we've sourced stainless steel locknuts and stainless steel serrated washers.
Min
Min
PostPosted: Sun May 11, 2008 8:59 am    Post subject: Reply with quote
For those of you interested in the design itself, check page 121 of maximum boost. you can clearly see which ones we copied.
Min
