Posted: Thu Jun 14, 2007 8:56 pm Post subject: MSD 6A Question |
I've got my MSD 6A installed and it works great - engine fired up nice first time! However when I turn OFF the ignition the engine continues to run!!
The doco talks about engine run-on and installing a pull down resistor to cure the problem - but it doesn't mention what size resistor to use... anyone know?
Cheers,
Gavin. _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
Posted: Thu Jun 14, 2007 10:26 pm Post subject: |
Shouldn`t need any resistor if the B+ (12V in) to the unit is on the switched line (15).
Or/ and the coil is switched and this unit grounds it.
If you can post a circuit I`ll work it out for you Gav.
Roger |
Posted: Thu Jun 14, 2007 10:37 pm Post subject: |
Yup, it's sure on a switched line... and after some more reading its a fairly common problem with the MSD units (and others such as Crane). You can either install a diode, or a Chysler Dual Ballast Resistor. I've found some on Ebay locally, so I imagine they are also available from AutoOne etc...
69 911 |
Posted: Fri Jun 15, 2007 12:07 am Post subject: |
A silicon diode will give you a voltage drop of 0.6v (GP types). Any resistor will too depending on its value and the current drawn if it is constant, which it probably wont be. This can be calculated according to ohm`s law.
I`ll keep my opinion of high current systems such as msd to myself.
As msd says it draws little current from the battery and actually suggest using a diode or resistor in series there is no reason why you cant connect it direct to the switched line 15. You could if you wish, connect a relay, coil to 15 and earth and NO contacts to the msd and battery, however it is not necessary and only another potential problem.
You havn`t shown the circuit to the coil. I am assuming the + is switched and - goes to the unit. The unit grounds the coil through a transistor and the battery connection provides power for the electronics. As I`m not familiar with the operation of your unit there is a slight possibility that it may require constant unswitched 12v but this would be a design fault as this is not even needed with programable units. (unless theyre crap too)
If not, can you detail the terminals on the unit. Bet a carton msd dont supply a circuit of the internals.
Roger |
Posted: Fri Jun 15, 2007 1:44 am Post subject: |
So its wired like this Gav?
Whatever msd suggest I dont know, but looking at that you want to connect both red wires to #15 at a suitable point. If the unit is under the hood go to the black/blue wire on your removed unit. Just run the black to a GOOD ground,
Your next question will be why doesnt my tacho work.
If you play the pokies hook your green tacho wire to the black - coil connection.
It probably grounds - to the coil like the bosch system but if it switches + well
Suggest measuring V at coil + when running. If constant 12-14 VDC youre OK If not you will need to buy an interface/adapter or make one yourself.
Roger |
Posted: Fri Jun 15, 2007 9:48 am Post subject: |
Pretty much yes, but my wiring doesn't match the Haynes for an '81 model, so I have no green/white on the Bosch unit (no idle stabiliser?), hence why I went for black/blue that it hooked to 15.
The + and - leads go straight to the battery terminals - only the on/off goes to a switched supply.
And yeah, the tacho no go, so I'll look into that later - I think someone mentioned you can hook the MSD tach output to the green/black that runs to tacho.
69 911 |
Min
Posted: Fri Jun 15, 2007 10:02 am Post subject: |
| pocketscience wrote: | | And yeah, the tacho no go, so I'll look into that later - I think someone mentioned you can hook the MSD tach output to the green/black that runs to tacho. |
Thats how I ran mine. Keep in mind also that the main reason for upgrading your ignition system like this is so you can increase your spark plug gap, so don't be timid with the gapping.
Posted: Fri Jun 15, 2007 10:17 am Post subject: |
Cool, thanks Min. Once it's all running then I'll start tinkering for optimal setup.
Cheers, _________________ Whoever said you can't buy happiness forgot about Porsche!
69 911 |
Posted: Fri Jun 15, 2007 10:52 am Post subject: |
Pocketscience wrote:
| Quote: | | The + and - leads go straight to the battery terminals |
Why is this necessary?
How much current does this thing draw over that of the coil. The #15 black /blue wire is 1.5mm2, rated at a max of 15 amps and not long enough for ,any significant voltage drop, certainly less than a diode.
It has no "memory" like a radio that requires 12V when your engine is off. Any residual current drain is not a good thing anyway especially for an ignition. If the current drawn is increased the load at the alternator is increased ever more so may actually have an adverse affect on performance.
If it has a tach terminal good, connect to green tach wire.
If you have a meter, select highest amps>10 and connect in series between this units B+ in and 12V, and measure consumption on standby and while running. Be interesting to see how efficient this thing is.
What coil are U running BTW?
Roger |
Posted: Fri Jun 15, 2007 11:25 am Post subject: |
Just standing on the shoulders of others Roger, and following the doco that came with it. I can see your reasoning though...
I'm using the MSD Blaster 2 coil, and Magnecore leads.
My new meter turned up today actually - sitting on my desk as I type this...! So will do some probing over the weekend.
Oh and to answer your earlier question - no they don't provide a circuit of the internals...!
69 911 |
Posted: Fri Jun 15, 2007 11:57 am Post subject: |
Well mate that coil would explain why msd reccomend direct connection to the battery. Uses 50 year old technology with a low impedence primary and high turns ratio.
Cant just use amps=volts/ohms (since it has an ac component that is affected by frequency (rpm) to calculate current.
Measure total current in series to battery. If <10A connect to #15. If it is more than that suggest using a relay to isolate unit from battery rather than rely on its internal switch(mechanical or silicon)
Measure the V on #15 in the off position too Gav, so we can get a better understanding of any leakage.
Roger _________________ World`s quickest 924 2L slushbox
| Allan @ DTA wrote: | | I have no issue with superchargers, they are for guys who want to drive a car rather than talk about horsepower with their baseball cap on backwards |
Posted: Sun Jun 17, 2007 9:14 am Post subject: |
| Min wrote: | | pocketscience wrote: | | And yeah, the tacho no go, so I'll look into that later - I think someone mentioned you can hook the MSD tach output to the green/black that runs to tacho. |
FYI, you need to connect the MSD tach output to the green only - I initially tied it to the green/black connection MSD suggest, but that didn't work.
69 911 |
Posted: Fri Aug 31, 2007 1:48 am Post subject: |
Hey all, a question on MSD install, and this seems like a good thread to do it on. We're trying to put an MSD6AL into Chris's racecar, to improve reliability as much as anything... question comes up, is the 924 "even-fire" or "odd-fire"? What's the difference, anyway?? This affects how you wire the rev limiter...
EDIT: never mind, I guess that's a distinction that only applies to 6-cyl cars... _________________ Vaughan Scott
Min
Posted: Fri Aug 31, 2007 2:15 am Post subject: |
| 924RACR wrote: | Hey all, a question on MSD install, and this seems like a good thread to do it on. We're trying to put an MSD6AL into Chris's racecar, to improve reliability as much as anything... question comes up, is the 924 "even-fire" or "odd-fire"? What's the difference, anyway?? This affects how you wire the rev limiter...
EDIT: never mind, I guess that's a distinction that only applies to 6-cyl cars... |
It doesn't only apply to 6 cylinders. But it refers to the space in degree's of crank movement between fires, so a even fire motor fires every x amount of crank degree's, while a odd fire fires at odd intervals of crank movement.
the 924 motor is definately even fire.
Posted: Fri Aug 31, 2007 4:37 am Post subject: |
Here's a long explanation of it -
http://home.off-road.com/~merls_garage/oddfire.html
The V6 odd-fire engine used for the example there fires at 90-150-90-150-90-150 degrees. An even-fire 6cyl would go at 120-120-120-120-120-120 degrees of crankshaft rotation.
(I didn't know about this before today - found it with a Yahoo search.)
Obviously our 4-cyls go evenly at 180-180-180-180.
An even-fire 8cyl would go at 90-90-90-90-90-90-90-90 degrees. _________________ "..it's made in Germany. You know the Germans always make good stuff."
