MikeDanger Guest
Posted: Wed Mar 06, 2002 3:35 pm Post subject: |
OK so The car want getting spark, and the mechanic finds out its the CDI box (the one on the fender) on my 80 931, he opens it up and one of the parts intenally has fried a conneting wire. Ok so ill have to replace that.
BUT!, when the car was getting spark it still wouldnt start. Now, im wondering if the cdi box was bad even when the car was getting spark, and therefore causing the car not to start(except for the ONE time that i got it started)
or could the non starting be mostlikely related to other stuff?
Thanks
Mike
AznDrgn Guest
Posted: Thu Mar 07, 2002 2:37 am Post subject: |
| There are other things you need to take into account. To get an engine to fire you need spark (at the right time), air, fuel (in the right mix), compression... There are endless possibilities, right now you haven't posted enough information to even start speculating about the problem. Post everything you know, all the tests you've run then we can start trying to help you troubleshoot. |
Chaz Guest
Posted: Thu Mar 07, 2002 3:14 am Post subject: |
Is this the same car that was trying to be started with no success over a year ago?
numbers Guest
Posted: Thu Mar 07, 2002 6:14 am Post subject: |
| Ignition box for an '80 on Ebay now. |
MikeDanger Guest
Posted: Thu Mar 07, 2002 5:21 pm Post subject: |
Yes this is the same one.
To the earlier question, I have checked everything, timing, fuel, spark etc. but nothing made much of a difference.
BUT i actually got it running once, dont really know how, but when it did run, it ran just fine,(but i couldn't drive it cause the tranny was out) I checked and rechecked everything. tried adjusting things this way and that, but to no avail. but before i gave up and decided to take it to a mechanic, it was firing every couple of revolutions after lots of cranking. like it almost wanted to start. |
Roger Hall Guest
Posted: Fri Mar 08, 2002 10:44 am Post subject: |
| sound like its no getting any fuel pull an injector and test it |
MikeDanger Guest
Posted: Fri Mar 08, 2002 12:15 pm Post subject: |
Yes, Again as ive said I HAVE CHECK ALL THAT, what ever anyone has, or is going to tell me to check, i already have.
its got to be something no one would think of.
But No one has answered my original question |
wdb Guest
Posted: Fri Mar 08, 2002 7:05 pm Post subject: |
| I had a power steering pump sieze up on me, (would not turn ) and the drag on the starter kept the rpm's down and the motor would not start . If there is anything keeping your starter from reaching a high enough rpm the motor wont start when its cold .try removing all unnecessary belts and see if that does it. if not hang a tire on the back of your car and get another car to push start it in 2nd gear in case your starter is headed south. if you have a catalytic converter,it might be clogged , the back pressure could prevent the car from starting . make sure your coil wire is not touching metal , it could bleed off enough juice to weeken the spark so it wont start but still have a spark. make sure the distributor is not 180 degress out . |
924 turbo Guest
Posted: Sat Mar 09, 2002 5:37 pm Post subject: |
Either you have a cold-start problem...
(have you checked the cold start system to see if the cold start valve is working? I would put the cold start valve on a switch so that it ran whenever you held a button down, just to make sure it was spraying while you were cranking)
...or I guarantee that your timing and mixture are off. You can spend all day fiddling with it and finally it will start and run with no problems. I suggest you spend a few hours with a battery charger and a friend and play with the timing and mixture until you've tried just about every possible setting. It's a really irritating process that I went through after I replaced my headgasket and clutch on my 924. It took about two hours to get it to start. Once you get the car running, it's easy to set the timing and mixture, but you need to get to that point first.
Best of luck.
MikeDanger Guest
Posted: Sat Mar 09, 2002 5:47 pm Post subject: |
Yes I have done all that, i have jumped the CS but it was 75 degrees, and the CS isnt supposed to be needed in this weather. Again, i got it running once, and it ran just fine, but then nextday it woudlnt start again. and i played with the mixture everywhich way.
the only time it fired for sure was when accidentaly I switched one of the plug wires and it backfired. |
924 turbo Guest
Posted: Sat Mar 09, 2002 6:00 pm Post subject: |
Where do you live? I'd be happy to come over and help if you're close.
Have you checked to see if the fuel pump is spraying enough fuel?
Have you checked the injectors individually?
How about the warm-up regulator? Have you tried swapping in a different one to see if it helped?
Is the air-flow meter centered?
Does it swing freely?
Has the fuel filter been replaced just in case?
Did you drain and replace the fuel?
Have the plug gaps been checked?
Is the exhaust plugged up somehow?
Sorry for the laundry list, but I'm not really sure what you have done.
MikeDanger Guest
Posted: Sat Mar 09, 2002 6:04 pm Post subject: |
yes ive done all that,
Im in houston |
924 turbo Guest
Posted: Sat Mar 09, 2002 6:08 pm Post subject: |
It must be an awfully strange problem...hmm...
One of you Texas guys, go over and help fix Mike's car!
wdb Guest
Posted: Mon Mar 11, 2002 10:54 am Post subject: |
| well , make any progress. got air fuel and spark. |
Joes924 Guest
Posted: Mon Mar 11, 2002 2:30 pm Post subject: |
Maybe just the box.
